Rear hugger help needed pls!! - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: Rear hugger help needed pls!! (/showthread.php?tid=73857) |
Rear hugger help needed pls!! - Fazer boy gilders - 20-09-15 Last night my hugger came loose the connector from the hugger to the swing arm sheered off can't seem to see any on eBay anybody and ideas pls where to get them. Re: Rear hugger help needed pls!! - Jules-C - 20-09-15 You got a photo? Every make of hugger uses different brackets Re: Rear hugger help needed pls!! - Fazer boy gilders - 20-09-15 I have but not sure how to upload on the page I'll keep trying or advise welcome cheers Re: Rear hugger help needed pls!! - Fazer boy gilders - 20-09-15 Pic attached Re: Rear hugger help needed pls!! - joebloggs - 20-09-15 Make one, if you can't fold alloy buy a short length of angle, cut it to length and drill a couple of holes to mount it. Simples Re: Rear hugger help needed pls!! - fazersharp - 20-09-15 (20-09-15, 08:06 PM)joebloggs link Wrote: Make one, if you can't fold alloy buy a short length of angle, cut it to length and drill a couple of holes to mount it.Yep thats right but I seem to remember from when i took mine off to paint that there were some locating pins to stop it twisting around the one bolt. Take it off and have a look Re: Rear hugger help needed pls!! - joebloggs - 21-09-15 If it does have a locating pin is that not an overkill on Yamaha's part. I understand why, just not sure it's needed. Chuck the pin away and save some weight.......... Re: Rear hugger help needed pls!! - bandit - 21-09-15 The location pin is on the hoop bracket that protects the rear brake hose,there's just a hole on the hugger bracket I've got which the pin goes through to the swinging arm. |
