Tachometer wont go above 2k rpm - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZ6 / FZ6 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=77) +--- Thread: Tachometer wont go above 2k rpm (/showthread.php?tid=73851) |
Tachometer wont go above 2k rpm - hellamatrix - 19-09-15 Hi! I am facing a issue with my FZ6-N S2 where the tachometer does not run above 2k rpm. However, it seems to be able to detect the correct rpm as long as it is below 2k. Is it a wiring issue or is the entire speedometer faulty? Re: Tachometer wont go above 2k rpm - Grahamm - 20-09-15 I've got the FZ6-SA (04-06 model) and on that when I cycle through the odometer/ trip 1/ trip 1 settings, there's also one that gives a numerical value for engine RPM. Does yours have something similar which might help? Re: Tachometer wont go above 2k rpm - hellamatrix - 22-09-15 Hi Grahamm, My FZ (07-09) model does not have the setting that will indicate the engine RPM sadly. Re: Tachometer wont go above 2k rpm - Grahamm - 25-09-15 Ah, sorry, then I'm out of ideas. |
