FZ6 extended clutch slave lever - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: For Sale & Wanted (https://foc-u.co.uk/mybb/forumdisplay.php?fid=80) +--- Thread: FZ6 extended clutch slave lever (/showthread.php?tid=73815) |
FZ6 extended clutch slave lever - davy41 - 15-09-15 Hi Would anyone on here know where its possible to buy an extended clutch slave lever for a 2005 reg bike Thanks in advance Re: FZ6 extended clutch slave lever - chaz - 15-09-15 I doubt if there is such a thing, if you want one because the clutch is heavy to use it may just need oiling. To do this get a plastic bag, disconnect the cable from the handlebar lever, cut a corner out of the bag just enough to get the nipple through then tape it to the cable outer to form a funnel. Put some light oil in the funnel and leave for a while, (tie it up) moving the inner cable too and frow will help, this can be done from the other end, or you could buy a cable oiler. Re: FZ6 extended clutch slave lever - joebloggs - 15-09-15 Go to the gym............... :lol Re: FZ6 extended clutch slave lever - davy41 - 15-09-15 Apparently there is a modified lever available but no idea where from Al gee u " go to the gym"!!! Re: FZ6 extended clutch slave lever - celticdog - 15-09-15 Shorty chinese levers are good and can help reduce clutch hand pain, search for it on the forum. Also, when it gets a bit stiff :rolleyes it might be time to replace the cable if lubing it don't make much difference. Re: FZ6 extended clutch slave lever - joebloggs - 15-09-15 (15-09-15, 09:33 PM)davy41 link Wrote: Apparently there is a modified lever available but no idea where fromSorry but you did kind of ask for it Issue I see with extension on the lever is how you going to take advantage of the extra leverage if it extends beyond the bar? |
