Clutch rattle in neutral? - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: Fazer 1000/FZ1 corner (https://foc-u.co.uk/mybb/forumdisplay.php?fid=75) +--- Thread: Clutch rattle in neutral? (/showthread.php?tid=73791) |
Clutch rattle in neutral? - mickvp - 13-09-15 Seems to be mentioned a few times on here, and my fazer has just started to do it too, but I haven't read how to get rid of it yet? Clutch is rattling only in neutral and only with the clutch out, as soon as I pull the clutch it goes away. My clutch adjustment seems fine though, so I'm not sure what to try first to remedy it, any thoughts? Re: Clutch rattle in neutral? - Falcon 269 - 13-09-15 They all do it. Don't sweat it.
Re: Clutch rattle in neutral? - b1k3rdude - 13-09-15 How many miles has the bike done? at a guess id say your clutch basket has some wear. As Mike says ist nothing to worry about, but if you really want to get rid of it - replacing the basket is the only way to go. Re: Clutch rattle in neutral? - mickvp - 13-09-15 Bike has only covered about 15000 miles (less I think actually), but then it's knocking on 11 years old now. As I say it's working fine, just hadn't noticed the noise in the past but then with the nice weather I have had my helmet flipped up and or my visor up more recently, so maybe I have just been hearing it better. Don't think I want to change the clutch basket over the head of it all the same, it's not THAT bad :lol Re: Clutch rattle in neutral? - Just Fazered - 18-09-15 [size=1em]Has it got the correct viscosity oil, because from what I've read and been told by a mechanic, it can make a difference to the clutch. That can include where if you've topped up your oil with a different type, that can make a difference? I'm about to change oil and filter on my Gen 1 Fazer thou which has clutch rattle in first gear when engine is cold - hoping it cures it and that's the advice I will be following. It is the cheapest and quickest cost option to try and eliminate the problem imho. Clutch change requires and oil and filter change anyway, so why not see if it cures it firstly? [/size] Re: Clutch rattle in neutral? - PieEater - 18-09-15 Mine is noisier in neutral with the clutch out than it is with the clutch pulled in, which as Mike said is normal behaviour for the bike (and he should know). I wouldn't try fixing a problem that doesn't exist. Re: Clutch rattle in neutral? - unfazed - 20-09-15 Put in your ear plugs before you start it :lol They all do it and it is worse if the carbs are out of synch. Re: Clutch rattle in neutral? - mickvp - 20-09-15 (18-09-15, 09:56 AM)Just Fazered link Wrote: [size=1em]Has it got the correct viscosity oil, because from what I've read and been told by a mechanic, it can make a difference to the clutch. Definately has the correct oil - Fuchs Silkolene 10W40 at the last oil change, and topped up with that ever since. I dont use anythign else for the Fazer. (18-09-15, 10:26 AM)PieEater link Wrote: Mine is noisier in neutral with the clutch out than it is with the clutch pulled in, which as Mike said is normal behaviour for the bike (and he should know). I wouldn't try fixing a problem that doesn't exist. I think your right, maybe I have noticed something thats always been there, im not sure :lol (20-09-15, 02:47 PM)unfazed link Wrote: Put in your ear plugs before you start it :lol carbs have not been done in a while - thats on my list for winter anyway as well as another filter/oil change so I will see what its like come spring time. |
