Speedo/Rev counters failing - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: Speedo/Rev counters failing (/showthread.php?tid=73721) |
Speedo/Rev counters failing - wilfmoralee - 05-09-15 Hi Having a problem with mainly my Speedo which fell to 0 about a week ago. It sporadically decides to work for a couple of minutes but falls very quickly again. Also, the rev counter has started doing the same, but works more often than the speedo. Originally I thought it may have been speedo sensor but with rev failing too it would suggest a fault elsewhere. So far I have checked and cleaned the multi plug going into the back of the clocks, and checked the speedo sensor was firmly in place. I have also checked all fuses. All other lights on the display (indicator etc) still work. Does anybody have any idea what the problem may be and how I could fix it? Many thanks |
