play with fire... - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: play with fire... (/showthread.php?tid=73707) |
play with fire... - Paulfzs - 04-09-15 incoming debate: Fzr 600 camshafts fit fzs 600... this would be pretty fun.. ill await foc-u to have their say on the matter. Re: play with fire... - Val - 04-09-15 (04-09-15, 12:09 AM)Paulfzs link Wrote: incoming debate: For gaud sake Paul leave the poor bike be it. Have you considered the possibility for a few months just to check the oil and ride it only no mods :lol That is animal cruelty :rollin :rollin Re: play with fire... - Paulfzs - 04-09-15 i do this a lot haha but now im exploring other things to do with it chances are i wont ever do it but i suppose if its easy and makes it better Re: play with fire... - red98 - 04-09-15 interesting that paul,always thought that theres a bit more power to come from the 600...fzr cam and some pod filters and with correct jetting you could be onto something
Re: play with fire... - Paulfzs - 04-09-15 fzr cams would improve things, id imagine stiffer springs would be needed too.... the whole carbs thing as far as im aware hasn't been looked at that much and jetting hasn't ever found a good balance without adding big flatspots, i suppose adding fzr cams, pod filter or similar high flowing filter slightly larger jets and it may well run so much better... problem being fzr cams are around £90 (fzs are £10-£15) then springs, + jets and filters then youre going to need a dyno... i will do some research and post back.. Re: play with fire... - kebab19 - 04-09-15 I thought the allure of the FZS600 was it's impressive midrange, provided primarily by smaller 33mm(?) carbs. What size were the FZR600 carbs? I assume instead you want a bike with a fairly gutless bottom end and then taking off up the rev range like a two stroke hitting it's powerband? That's certainly what my 89 FZR600 used to do This could also get quite expensive... Re: play with fire... - riedrider - 04-09-15 Quote:I thought the allure of the FZS600 was it's impressive midrange,That´s the reason why I bought it I think that any change like other cams or end cans will spoil that... |
