rider left footpeg loose - Printable Version
+--- Thread: rider left footpeg loose (/showthread.php?tid=73649)
Pages: 1 2
rider left footpeg loose - Paulfzs - 30-08-15
more problems...
rider left footpeg is loose and has a lot of play...
how do i solve this?
Re: rider left footpeg loose - slappy - 30-08-15
How does it actually fasten on?
Re: rider left footpeg loose - Paulfzs - 30-08-15
i cant quite tell, it goes through into the hanger but looks like possibility of a C clip
See if you can actually remove the footpeg, if so is the shaft where it fastens on worn, or if there are any bushes worn that would  cause it to feel loose.
Re: rider left footpeg loose - Val - 30-08-15
(30-08-15, 07:32 PM)Paulfzs link Wrote: i cant quite tell, it goes through into the hanger but looks like possibility of a C clip
Actually there is big hex bolt part number 90109-103A9 at the back of the hanger (the heel plate). You need to remove the hanger first than unsrew the hex bolt and remove the foot peg.
Having said that what do you mean loose? Mine left foot peg has some free swivel play and can rotate a little about 30 degrees. I hope that is normal and by design  :lol
its well loose!
looser than its ever been...
this loose...
https://www.youtube.com/watch?v=cULL5GHEf2s
Re: rider left footpeg loose - fazersharp - 30-08-15
Yes you need to undo the two hex bolts on the left as well as loosening the gear change leaver bolt ( mark the position on the shaft first) then slide off the whole lot.
The 10mm - i think hex bolt at the back of the kick plate from factory is fecking tight of tight town tighty so if yours is loose then it must of been removed in the past and not put back tight enough also it should have from factory a locktight on it. Take it out aply  locktight and do it up to tight - tighty town, tight
Re: rider left footpeg loose - Val - 31-08-15
(30-08-15, 11:57 PM)fazersharp link Wrote: Yes you need to undo the two hex bolts on the left as well as loosening the gear change leaver bolt ( mark the position on the shaft first) then slide off the whole lot.
:agree Looks to me your hex bolt is loose.
Re: rider left footpeg loose - Paulfzs - 31-08-15
got it off....
twisted a hex key trying to get the hanger off!
the footpeg hex bolt was almost all the way out! done back up as tight as i could and all reassembled
Re: rider left footpeg loose - darrsi - 31-08-15
That's not a sudden thing, how have you not noticed that before?
(31-08-15, 11:32 AM)darrsi link Wrote: That's not a sudden thing, how have you not noticed that before?
Its always been a little loose but recently i did do a big long ride which was bumpy country lanes and a lot of motorway so im guessing this just finished it off.
Re: rider left footpeg loose - fazersharp - 31-08-15
What physics are at play --- why is it that any vibration loosens a nut and not tightens a nut.
If your bike was an animal you'd be done for cruelty.  :rollin
Me thinks that you posted that one in the wrong thread
Should that have gone in the choke one
(31-08-15, 01:27 PM)darrsi link Wrote: If your bike was an animal you'd be done for cruelty.  :rollin
(31-08-15, 01:33 PM)fazersharp link Wrote: Me thinks that you posted that one in the wrong thread
[quote author=darrsi link=topic=18083.msg208633#msg208633 date=1441024055]
Nope!
(31-08-15, 01:35 PM)fazersharp link Wrote: Should that have gone in the choke one
Heard you the first time!
Nope!
Re: rider left footpeg loose - unfazed - 31-08-15
Go on Fazersharp, tell him again  :rollin :rollin :rollin
Well I dont get it then
Id get done for animal cruelty but id be up in court with about 4.8 million trees worth of receipts where ive bought parts and treated this bike but still it shows me so much hate.
