Lowering rear brake lever - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: Lowering rear brake lever (/showthread.php?tid=73552) |
Lowering rear brake lever - Xander567 - 18-08-15 Is it possible to lower the rear brake lever? Don't really want to try and test it without knowing if it's possible first. The gear lever is at a good height and i can get my foot on and under it without needing to lift the foot. But the brake lever requires actual lifting. It's not a major issue, just thought i could make it a bit more comfortable. It's a '97 FZS600. Re: Lowering rear brake lever - Punkstig - 18-08-15 Yes it is possible, Hope this helps! Re: Lowering rear brake lever - Xander567 - 18-08-15 it does, thanks. I can give it a go then and not worry that i'm wasting my time. Re: Lowering rear brake lever - clayt74 - 18-08-15 Lol, just make sure you adjust the brake light switch at the same time!! Re: Lowering rear brake lever - red98 - 18-08-15 Classic foc-u :lol.....I think its possible as well
Re: Lowering rear brake lever - Sidewinder - 26-08-15 Hope you sorted it bud, I just had to raise mine t'was easy and nothing to worry about 10 mins job. |
