project small sun complete ( i think) - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: project small sun complete ( i think) (/showthread.php?tid=73488) |
project small sun complete ( i think) - Paulfzs - 11-08-15 so, got main beam sorted with 2x 20w led spotlights... dip beam still lacked even with an osram night breaker and the little cup removed.. so i purchased a h1 hid bulb from ebay.. then a ballast.. only to find the ballast didn't come with the wiring harness. ordered harness it arrived today so i set about fitting it ... luckily the wiring harness has really odd length wires to make it super difficult... the battery to relay wire was super short meaning the relay needed to be kind of close to the battery.. and the plug from the relay that plugs into the fazers h1 plug was also short meaning somehow i had to stretch it from near the battery to the front of the bike.. then the power from the relay to the ballast was about 20-30 feet long meaning i had to coil it up loads. ![]() settled on a place for the ballast and relay works pretty well here.. strong double sided tape holding it against the cross member and some ghetto double sided tape on top just because why not. (yes i did take the black wiring box out during the engine change and forgot to put it back in) ![]() just my dip beam on ![]() And for when i wish to go into overkill mode... ![]() Re: project small sun complete ( i think) - Fazerider - 11-08-15 Just as well the MOT was yesterday, eh? :rolleyes Re: project small sun complete ( i think) - Paulfzs - 12-08-15 (11-08-15, 09:32 PM)Fazerider link Wrote: Just as well the MOT was yesterday, eh? :rolleyes spotlights passed the mot and it passed with no bowl over the dip beam. besides, i like to see where im going. Re: project small sun complete ( i think) - Paulfzs - 14-08-15 Soo tested and 35w isnt that bright, ordered a new slim 55w ballast so will see how it goes. Re: project small sun complete ( i think) - sinto607276 - 14-08-15 Paul, that pic of the ballast and wires that you posted seems odd :-( Deffinetly too many wires. You shouldn't have a relay for a start, you only need a relay if your connecting a H4 HID as that requires it for the dual element, I think they've sent the wrong wiring loom for your needs. I'll take some pics tomorrow and post them for you to see. You should have the ballast, the two sets of wires coming out of it, one goes to the HID bulb, the other to the original H1 connection from the bike. I wouldn't imagine you'd have enough wire to run all the way back to the battery section, I installed my ballast in the left hand side, under the plastic and used a bracket to secure it to the bolt that goes through the left hand fairing. When I do my H4, I'll just put it under the right hand side fairing in the same way,but will need to run a lead to the battery. So if, your going to upgrade the H4, you've already got the wires for that. :-) Re: project small sun complete ( i think) - Paulfzs - 15-08-15 ive got a slim 55w ballast now but yeah the harness seems to have a lot of wires but google Quote:An Automotive Relay is used to pull signal from a source (Headlight connector) that triggers power to be drawn from the battery.[size=1.35em] [/size] this harness goes from the battery to the ballast and to the h1 headlight connector, its drawing straight from the battery which is apparently why it needs the relay? Quote:Here is the answer, a time delay relay. This relay fits most common single beam HID wiring harnesses for an easy fix to prevent HID from starting before/during cranking the engine. Avoid those pesky ignition errors, flickering/fluttering HID, and the needless wear and tear on bulbs. Re: project small sun complete ( i think) - fazersharp - 15-08-15 Whats that in the middle of your fairing just above the box lights, it even has a cut out for it, some kind of weird aftermarket thing ? Re: project small sun complete ( i think) - sinto607276 - 15-08-15 (15-08-15, 11:59 AM)Paulfzs link Wrote: ive got a slim 55w ballast now but yeah the harness seems to have a lot of wires but google I've never used a relay in any of my HID's that I've fitted to bikes and cars and never had any issues with them. Only ever wired them up as I said previously. Plus, your lights are switched on after the bike is running so I don't think it affects it the way they're saying. Only time that a relay was mentioned to me was when I investigated into the H4 which has a dual element and every seller/user of these bulbs all said I'd need a relay for that bulb. Think you've been told differently, but that's not a bad thing as you now have the proper one for when you go to do your H4, but if your not, give me a shout and I may buy it off you, although I'm not keen on the thicker ballast. ![]() Colin Re: project small sun complete ( i think) - Paulfzs - 15-08-15 (15-08-15, 02:37 PM)sinto link Wrote: [quote author=Paulfzs link=topic=17922.msg207253#msg207253 date=1439636373] I've never used a relay in any of my HID's that I've fitted to bikes and cars and never had any issues with them. Only ever wired them up as I said previously. Plus, your lights are switched on after the bike is running so I don't think it affects it the way they're saying. Only time that a relay was mentioned to me was when I investigated into the H4 which has a dual element and every seller/user of these bulbs all said I'd need a relay for that bulb. Think you've been told differently, but that's not a bad thing as you now have the proper one for when you go to do your H4, but if your not, give me a shout and I may buy it off you, although I'm not keen on the thicker ballast. Colin [/quote] Ive got a 55w slim ballast and 35w big ballast, the 55w slim turned up yesterday, i didnt realise till after i ordered a big ballast. Re: project small sun complete ( i think) - Paulfzs - 15-08-15 (15-08-15, 12:21 PM)fazersharp link Wrote: Whats that in the middle of your fairing just above the box lights, it even has a cut out for it, some kind of weird aftermarket thing ? camera mount
Re: project small sun complete ( i think) - Paulfzs - 18-08-15 ordered a set of 2 55w bulbs and its come with the wiring for the ballast too.. why didnt i order this in the first place! so now ive got 2x 35w h1, 2x 55w h1 1x 35w ballast, 1x 55w ballast, 1x big wiring harness and 2x small wiring harnesses... all i wanted was better lighting! Re: project small sun complete ( i think) - sinto607276 - 18-08-15 (18-08-15, 02:13 PM)Paulfzs link Wrote: ordered a set of 2 55w bulbs and its come with the wiring for the ballast too.. why didnt i order this in the first place! If you ordered 2 x 55w, how come you then say you've got 2 x 35w and the other stuff? I can see (excuse the pun) some stuff in the for sale section soon :rollin
Re: project small sun complete ( i think) - Paulfzs - 18-08-15 (18-08-15, 04:16 PM)sinto link Wrote: [quote author=Paulfzs link=topic=17922.msg207503#msg207503 date=1439903607] If you ordered 2 x 55w, how come you then say you've got 2 x 35w and the other stuff? I can see (excuse the pun) some stuff in the for sale section soon :rollin [/quote] i got 2 35w bulbs on ebay for like £2 bidding ![]() so ordered the ballast to match then had to order the harness, then it wasnt good enough so ordered a 55w ballast.. still not great so ordered 2x 55w bulbs which came with their own wiring lol. so ive got 2 sets now.. slim 55w kit with 2 h1 bulbs large 35w kit with 2 h1 bulbs Re: project small sun complete ( i think) - Paulfzs - 19-08-15 just got back from testing it, any excuse to go for a ride ![]() i barely used my full beams really, so much better! only problem is it flickers a bit once its warmed up. Re: project small sun complete ( i think) - sinto607276 - 19-08-15 Best time to find out how good they are is in the dark :rollin Can't figure out what you mean by 'flickering'? How many bulbs you done in HID? Have you got sound connections? Where you located the ballast might not be helping as there's lots of electrical wires about there. Try moving it to somewhere else. Re: project small sun complete ( i think) - Paulfzs - 19-08-15 its like this: https://youtu.be/AK-Xhu0qjZU?t=25s my 35w didnt do it with either 35w or 55w ballast, its fine untill it warms up. ballast is on the fairing left hand side, all plugs in correctly. Only got the left h1 bulb connected. Re: project small sun complete ( i think) - sinto607276 - 19-08-15 The kit he installed on the video is the ones I use, I've not had any problem with them flickering, so maybe if yours aren't the same that's the reason? Re: project small sun complete ( i think) - Paulfzs - 19-08-15 Yeah mine doesnt have a capacitor, its not been a problem up untill now... ill go into maplins tomorrow and buy one for £1 to solder on or just spend £5 and buy one off the auction site. |
