Has anyone replaced sprocket cover/Shift shaft seals with roller bearings ??? - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: Has anyone replaced sprocket cover/Shift shaft seals with roller bearings ??? (/showthread.php?tid=73457) |
Has anyone replaced sprocket cover/Shift shaft seals with roller bearings ??? - Sandscorcher - 08-08-15 Ok this might be a crap idea but if you don't try, I guess you don't know I'm thinking of replacing the seals for the shift shaft on my sprocket cover with sealed roller bearings that I used to use in radio control cars. Was just thinking it might give the shaft a little extra stability Has anyone else tried this ? Re: Has anyone replaced sprocket cover/Shift shaft seals with roller bearings ??? - Fazerider - 09-08-15 Never heard of anyone trying that, but the amount of movement there bothers me too. Not that it really should… even on hundred thousand mile motors it doesn't seem to cause an oil leak and the slop at the lever tip is mostly due to wear at the pivot. My lever had so much free play the tip could be waggled around a wonky circle of about 2' diameter until I changed the lever and foot peg yesterday. :lol Re: Has anyone replaced sprocket cover/Shift shaft seals with roller bearings ??? - Sandscorcher - 09-08-15 Think next time the covers off i'll pull the seals out & get some measurements instead of guessing. Re: Has anyone replaced sprocket cover/Shift shaft seals with roller bearings ??? - Sandscorcher - 03-09-15 Ok its been a while but I've now had the Sprocket cover off Pulled the Shift shaft seals out & cleaned up the recesses, tried the bearings to see if they were actually going to fit or not. They fitted a treat, nice & snug as they needed tapping in, so cant see them coming out unless there tapped put. What a difference they've made, No more shaft play at all & shiftling gear now feels so much better. ![]() I so wish I'd done this sooner :wall The bearings used were bought from Ebay (seller - Leomaxx22) Advertised as "2pc 12x18x4 Rubber Sealed Ball Bearing Tamiya Kyosho Traxxas" They only cost £2.13 so even if they only last a year they ain't going to break the bank :lol Re: Has anyone replaced sprocket cover/Shift shaft seals with roller bearings ??? - Jules-C - 03-09-15 That's a nice little modification. Just remember not to pressure wash them Re: Has anyone replaced sprocket cover/Shift shaft seals with roller bearings ??? - Sandscorcher - 03-09-15 (03-09-15, 05:23 PM)Jules-C link Wrote: That's a nice little modification. Just remember not to pressure wash them Cheers, Never pressure was the bike anyway (hardly gets cleaned :lol ) Re: Has anyone replaced sprocket cover/Shift shaft seals with roller bearings ??? - joebloggs - 07-09-15 (03-09-15, 01:21 PM)Sandscorcher link Wrote: Ok its been a while but I've now had the Sprocket cover offDid you have to modify the case? Bearing single or double shielded? Re: Has anyone replaced sprocket cover/Shift shaft seals with roller bearings ??? - Sandscorcher - 07-09-15 No mods to case, just remove the seal & clean out any crap before fitting the bearing. The bearings I use are rubber sealed on both sides, hope that helps. Re: Has anyone replaced sprocket cover/Shift shaft seals with roller bearings ??? - joebloggs - 07-09-15 (07-09-15, 08:23 AM)Sandscorcher link Wrote: No mods to case, just remove the seal & clean out any crap before fitting the bearing.Thanks Ordered May be useful as I'd like to reverse my shift if possible |
