K-tech spring kit for the FZS1000 - addition info req. - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: Fazer 1000/FZ1 corner (https://foc-u.co.uk/mybb/forumdisplay.php?fid=75) +--- Thread: K-tech spring kit for the FZS1000 - addition info req. (/showthread.php?tid=73450) |
K-tech spring kit for the FZS1000 - addition info req. - b1k3rdude - 08-08-15 Got a K-tech fork spring kit fitted yesterday and I as fas as I can see its made bugger all difference, so before I call k-tech -
Re: K-tech spring kit for the FZS1000 - addition info req. - sadlonelygit - 08-08-15 how heavy are you? sag should be @25mm with rider. damping is up to you. 8.5W oil seems pretty heavy duty! Re: K-tech spring kit for the FZS1000 - addition info req. - Falcon 269 - 08-08-15 Call k-tech and don't waste time waiting for answers here. ![]() Seriously, they're the experts and best placed to advise on their product as fitted to the Gen 1. You should ask about air gap as well as oil weight. Re: K-tech spring kit for the FZS1000 - addition info req. - sadlonelygit - 08-08-15 (08-08-15, 06:01 PM)Falcon 269 link Wrote: Call k-tech and don't waste time waiting for answers here. NOOOOOOOOOOOO!!!!! i was hoping for 5 pages of speculation, tyre pressures, profiles, leathers colours and a lucky T shirt. Re: K-tech spring kit for the FZS1000 - addition info req. - b1k3rdude - 09-08-15 (08-08-15, 05:39 PM)sadlonelygit link Wrote:
Re: K-tech spring kit for the FZS1000 - addition info req. - sadlonelygit - 09-08-15 imo 9nm is a little too soft for your weight. my little suspension website says 0.999 kg/mm is optimum spring. Re: K-tech spring kit for the FZS1000 - addition info req. - b1k3rdude - 09-08-15 (09-08-15, 10:20 AM)sadlonelygit link Wrote: imo 9nm is a little too soft for your weight. my little suspension website says 0.999 kg/mm is optimum spring.Dosen't feel that way when I sit on the bike, will speak to KT on Monday to get all the settings etc. Re: K-tech spring kit for the FZS1000 - addition info req. - mark g - 09-08-15 I hope you get sorted matey, I must admit I think my forks feel fine as they are, if I'm honest even the rear shock isn't that bad certainly not as bad as some folk report Re: K-tech spring kit for the FZS1000 - addition info req. - sadlonelygit - 09-08-15 stronger springs need less compression and more rebound damping. when mine was upgraded i had max rebound with 5w oil at 140 air gap. be interesting to hear what ktech have to say. mind you this is the same ktech who sent me 2 differently wound springs in a set. :rolleyes Re: K-tech spring kit for the FZS1000 - addition info req. - unfazed - 09-08-15 (09-08-15, 01:00 PM)sadlonelygit link Wrote: mind you this is the same ktech who sent me 2 differently wound springs in a set. :rolleyes Were you using those springs in Oulton? :lol :lol :lol Re: K-tech spring kit for the FZS1000 - addition info req. - b1k3rdude - 12-08-15 So got an update from k-tech -
Re: K-tech spring kit for the FZS1000 - addition info req. - PieEater - 12-08-15 Compression & rebound settings are based on so many variables (including the oil weight - which is lighter than they recommended) that no-one can give you the correct ones for you, you just need a base and then to go out and find what suits you best. I've found it helps to go out with a mate and get them to adjust the settings without you knowing what they've done, ride like you normally would and see if the ride is better or worse then rinse and repeat until you're there. Personally I think static / rider sag is all well and good but I would stick a cable tie on one of the legs and adjust preload to the point that in regular riding you are using most of the travel but have about 10mm left in reserve. I recently upgraded my 13 year old OEM springs (and oil :eek) with K-Tech 10NM and 10W (as recommended) and found the difference to be pretty noticeable, that being said I'm "big boned" and the OEM springs had probably long given up the ghost. You seem to have pretty much replaced like for like so I wouldn't be that surprised if the difference was subtle, but it should be noticeable. Re: K-tech spring kit for the FZS1000 - addition info req. - unfazed - 12-08-15 (12-08-15, 07:18 PM)b1k3rdude link Wrote: So got an update from k-tech - I think they got it in reverse, I would suggest as a start 4 out rebound and 8 out compression |
