sprocket cover oil leak - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: sprocket cover oil leak (/showthread.php?tid=73426) |
sprocket cover oil leak - Paulfzs - 06-08-15 i think ive found the source of my oil leak, it appears to be from one of the bolt holes :S the sprockets been off and no oil behind, clutch rod no oil, gear shaft no oil and a bolt hole seems to be full of oil.. now what? the oil leak is noticeable after like 30+ miles itll leave a puddle the size of 2 50p coins. Re: sprocket cover oil leak - darrsi - 06-08-15 Would that be suggesting a cracked casing then? Sounds a bit like this: http://www.gixxer.com/forums/showthread.php?t=240279 Re: sprocket cover oil leak - Paulfzs - 06-08-15 could be a cracked case, would be cracked inside the bolt hole itself :/ ptfe tape on the bolts i think then and see what happens. Re: sprocket cover oil leak - darrsi - 06-08-15 (06-08-15, 02:12 PM)Paulfzs link Wrote: could be a cracked case, would be cracked inside the bolt hole itself :/ It's not good whichever angle you look at it unfortunately. Try the tape though, you certainly have nothing to lose. Re: sprocket cover oil leak - Paulfzs - 06-08-15 no idea how it could have cracked, engines only done 23k miles! ill investigate! Re: sprocket cover oil leak - darrsi - 06-08-15 (06-08-15, 04:09 PM)Paulfzs link Wrote: no idea how it could have cracked, engines only done 23k miles! Over tightening the bolts would be my guess. Re: sprocket cover oil leak - Paulfzs - 06-08-15 (06-08-15, 04:55 PM)darrsi link Wrote: [quote author=Paulfzs link=topic=17860.msg206356#msg206356 date=1438873777] Over tightening the bolts would be my guess. [/quote] i blame sinto! ill sort it, i always do.. even if it means filling it with jb weld! Re: sprocket cover oil leak - Paulfzs - 28-08-15 so finally attacked this... took cover off gave it all a wash out, the right hand side bolt was covered in oil when i took it out and a little oil dripped out the bolt hole so yep... upon looking the reason its actually coming out is.... the sprocket cover bolt guide we will call it had 2 notches cut out of it, not sure if thats how theyre made (someone confirm?) and the bolt looked like its been caught on something and flattened the thread on 2 parts of it which appear to line up with these 2 big notches :S maybe something happened and damaged them both? i wrapped it in a metric fuckton of ptfe tape and bolted it back together, and as of yet ive only had maybe 2-3 drops of oil which ill guess are whats left inside the casing/side of engine. |
