Occasional problem changing gear - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: Fazer 1000/FZ1 corner (https://foc-u.co.uk/mybb/forumdisplay.php?fid=75) +--- Thread: Occasional problem changing gear (/showthread.php?tid=73416) |
Occasional problem changing gear - jeffco - 04-08-15 For a while now I seem to have a problem changing down gears if I have brought the bike to a stop without down changing as I slowed, when im stopped and I try to change down it will go down to about 3rd them wont go further without a bit of jiggling about. Other than that the gearbox is fine, no missed/ sticky gears and changes down fine if I change down as im slowing. Is this a common problem? or are dark clouds forming on my horizon ? You can tell that ive just had a week in Scotland , still looking for bloody dark clouds... Re: Occasional problem changing gear - unfazed - 04-08-15 That would be normal enough as the gears need to be rotating to mesh properly. Let the clutch in and out a bit to get the gears to rotate a bit to the correct position when changing at a standstill. Re: Occasional problem changing gear - ste131 - 04-08-15 Yeah, its normal. It has to select through rotation. Just go down the gears before you stop or slip clutch. Catches us all out sometimes when we think brakes first! Re: Occasional problem changing gear - jeffco - 04-08-15 Thanks lads.... It only happened cos it was pissing down and I had to stop pretty sharp, I was more concerned about staying on it than changing gears. Re: Occasional problem changing gear - unfazed - 05-08-15 (04-08-15, 08:45 PM)jeffco link Wrote: Thanks lads.... It only happened cos it was pissing down and I had to stop pretty sharp, I was more concerned about staying on it than changing gears. I guess most of us have been in that situation once or twice :lol |
