wanted rear caliper - fingers crossed fazer 1000? - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: For Sale & Wanted (https://foc-u.co.uk/mybb/forumdisplay.php?fid=80) +--- Thread: wanted rear caliper - fingers crossed fazer 1000? (/showthread.php?tid=73393) |
wanted rear caliper - fingers crossed fazer 1000? - cuxoni - 02-08-15 I've just bought a mark 1 fazer and the rear caliper is seized solid. I'm after a replacement. Hopefully I'm going to strike lucky and find one off a fazer 1000, buy since beggars can't be choosers any will do as its currently off the road. Cheers. Re: wanted rear caliper - fingers crossed fazer 1000? - unfazed - 02-08-15 Widen your search to include the XJR1300 from 2003 on, as the rear blue spot on those will fit also Re: wanted rear caliper - fingers crossed fazer 1000? - cuxoni - 02-08-15 Cheers, A bit (loads) more than I fancied paying but would this one work? http://pages.ebay.com/link/?nav=item.view&id=141110288445&alt=web if so I'll keep my eye out cos thats 1/7 of what the bike cost :eek Re: wanted rear caliper - fingers crossed fazer 1000? - unfazed - 02-08-15 That is vastly over priced and does not look in great condition. Are you sure you own is not repairable. Re: wanted rear caliper - fingers crossed fazer 1000? - unfazed - 02-08-15 Here is one, but photographed from the reverse side http://www.ebay.co.uk/itm/YAMAHA-XJR-1300-2005-2006-BRAKE-CALIPER-REAR-USED-MOTORCYCLE-PARTS-/141679660716?hash=item20fcc40eac Re: wanted rear caliper - fingers crossed fazer 1000? - cuxoni - 03-08-15 Cheers for the response, ill carry on searching. I removed the old one, split it, heated it, soaked it in wd40 and the only way to get it to shift was with 2 wooden blocks and hammer which was a last resort and not much use as it's made the pot go in not out. I cant twist or pull or anything, I tried blowing it off with a bike pump contraption I rigged up but that was also unsuccessful but I backed out at about 80psi scared. After 4 hours of messing about I thought a replacement would be the better thing to do.... I might try the pump again now its had the hammer treatment but dont want to be back doing this again in a few months. Re: wanted rear caliper - fingers crossed fazer 1000? - sinto607276 - 04-08-15 Try searching on USA ebay, when anutz was looking for one, we tracked down a good one for him and even with the import tax etc, was way cheaper than getting from UK Send anutz a message, I'm sure he'll fill you in with the details. You said you tried the pump method, did you put a small bit of wood inbetween the pistons and have both sides on? Re: wanted rear caliper - fingers crossed fazer 1000? - RMT1983 - 04-08-15 Ive sent you a link to one for $34.99 - he wants $55 for the postage then you will have custom charges but still not a bad price mate Re: wanted rear caliper - fingers crossed fazer 1000? - unfazed - 05-08-15 Cuxoni, another option is to split the caliper and have the pistons pressed out. |
