2nd gear gone again - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: Fazer 1000/FZ1 corner (https://foc-u.co.uk/mybb/forumdisplay.php?fid=75) +--- Thread: 2nd gear gone again (/showthread.php?tid=73391) |
2nd gear gone again - bigfootpete - 02-08-15 Are these gears made out of tin foil? This is the second time my second gear has lost teeth. Ok, first time I tried too many wheelies, but I don't bother with those any more. My gear changing is smooth - mostly :-) Are aftermarket gear cogs any better? Re: 2nd gear gone again - AyJay - 02-08-15 Is it a 2001 model? The second gear on R1s and Fazers 2000/2001 were superseded by an uprated part. Poor undercutting on the dog, apparently. See "Replaced part number" here https://www.motorcyclespareparts.eu/yamaha-parts/motorcycles/fzs1000-fazer-2001/transmission-348946/5jj171210000-gear-2nd-pinion.aspx Re: 2nd gear gone again - Mark YPVS - 04-08-15 make sure when you change 2nd you change 6th and the selector fork as well, had to do my R1 5PW ( same gear box). Mark
Re: 2nd gear gone again - sirgalahad3 - 04-08-15 If you follow the line back Yamaha suffered from the same problem on the xs1100. Second gear on them was very fragile on them and they didn't seem to correct it on the early 1000 boxes. Mine is 03 and seems ok but being a xs11 owner I never harsh change second... Re: 2nd gear gone again - bigfootpete - 04-08-15 It's a 2003 model, thanks will make sure I get 6th and selector done too. Re: 2nd gear gone again - unfazed - 04-08-15 The uprated 2nd gear (again) part number is 5JJ-17121-01 not 5JJ-17121-00 it was changed again in the later fazers Re: 2nd gear gone again - bigfootpete - 31-03-17 Me again, talk about procrastinating! I've been riding around mostly changing straight up to third to avoid second. Just ordered the gears, but apparently there are three selector forks, so anyone know which one to replace? |
