starting relay cut off 5EB 81950 20 Do you have one I can swap with you and test - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: Fazer 1000/FZ1 corner (https://foc-u.co.uk/mybb/forumdisplay.php?fid=75) +--- Thread: starting relay cut off 5EB 81950 20 Do you have one I can swap with you and test (/showthread.php?tid=73385) |
starting relay cut off 5EB 81950 20 Do you have one I can swap with you and test - vinnychoff - 01-08-15 I hope you can help me to test this relay or I wonder if anyone is local to Croydon. That I could fit this relay on their bike and see if it is working. At the moment I have the neutral light on all the time. I can hear the relay click when I pull in the clutch lever. I also need a side stand switch as that is faulty. My neutral light switch was seized so had to get one of those. If you can help or suggest. Thanks in advance Vince Re: starting relay cut off 5EB 81950 20 Do you have one I can swap with you and test - Falcon 269 - 02-08-15 Not local, so can't help much in practical terms. However, you could try removing and cleaning both neutral and side stand switches if you haven't already. Both get really crudded and oiled up but provided the wiring is intact, it's possible to blast the crap out of the switch internals with WD-40. You can also jump the contacts on the sidestand switch as a get-you-going measure and/or for fault-finding. Re: starting relay cut off 5EB 81950 20 Do you have one I can swap with you and test - b1k3rdude - 02-08-15 If Falcons tip dosent help, where abouts are you? If you too far away from me, you have the option of buying one off ebay for £15 - - http://www.ebay.co.uk/itm/Yamaha-FZS1000-FZS-1000-Fazer-Starter-Solenoid-Relay-/390100835692 Re: starting relay cut off 5EB 81950 20 Do you have one I can swap with you and test - vinnychoff - 03-08-15 Thanks for your help. I have removed the side stand switch as it is faulty and ordered a new neutral switch. I started a blog and uploaded a video for others if they need help. i could not find easily how to remove the neutral switch. https://yamahafzs1000.wordpress.com/2015/07/31/hello-world/?preview=true&preview_id=2&preview_nonce=74c8e26188 Re the starting relay. It looks like a large relay with about 16 connections on it. It is under the side panel on the same side as the side stand. I have found the neutral light on the dash is on all the time even if the switch is disconnected. Re: starting relay cut off 5EB 81950 20 Do you have one I can swap with you and test - Falcon 269 - 03-08-15 Hi Vince, Handy video, thanks. I don't know if you tried searching the US FZ1OA forum but that's good resource to dip into. This post may give you some clues to trace your permanently on neutral light: http://www.yamahafz1oa.com/forum/showthread.php?t=54389&highlight=neutral+switch+light Re: starting relay cut off 5EB 81950 20 Do you have one I can swap with you and test - vinnychoff - 04-08-15 Falcon thaks that is what i was searching for. Very helpful. thank you again. Vince Re: starting relay cut off 5EB 81950 20 Do you have one I can swap with you and test - unfazed - 04-08-15 If you need to buy the relay it is also used in the 2000-2003 R6 the 2000-2001 R1 and all the Gen1 Fazers |
