HID Headlights - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: Fazer 1000/FZ1 corner (https://foc-u.co.uk/mybb/forumdisplay.php?fid=75) +--- Thread: HID Headlights (/showthread.php?tid=73336) |
HID Headlights - mark g - 26-07-15 Thinking of fitting a HID conversion to my gen 1, looked at LED bulbs after watching a ruck of youtube vids I think the HID Xenon type might be the way to go. Has anybody fitted a kit to there bike and if so are they any better than the OEM and lastly do they pass the MOT ok?. Re: HID Headlights - sadlonelygit - 26-07-15 yes yes yes Re: HID Headlights - mark g - 26-07-15 I guess that's a yes then :b any particular make to buy / avoid ? Cheers buddy Re: HID Headlights - PaulSmith - 27-07-15 Fitting HID bulbs has been the single best safety improvement I have made to any bike I have ever ridden. My first kit was a cheap and nasty Chinese one from ebay that cost about £25 and the bulbs only lasted about six months, but it was still the absolute dogs dangly bits. It was a car kit so the cables for one bulb were much longer then for the other so finding somewhere to tidy them out of the way was a bit of a nuisance. Do not go for the high K values as apart from looking naff (IMHO) and attracting unnecessary attention, they simply do not put as much visible light on the road. I would recommend bulbs between 4500K and 6000K and if you go for the H4-3 type kits then you get normal and full beam. (An electro-magent in the bulb housing physically moves the bulb from one position to the other and back.) You do not have to make any permanent changes to the bike if you don't want to so you can put it back to standard when you sell it on, just run one power line from the battery to the back of the clocks. One thing to watch out for are the H4 bulbs with the billet looking aluminium body such as these http://www.ebay.ie/itm/Car-35W-HID-H4-Conversion-Hi-Lo-Beam-White-Headlight-Light-Bulbs-Lamp-New-/350834496203?pt=LH_DefaultDomain_3&hash=item51af5d92cb because the body does not disconnect from the reflector so you can not get them through the rubbers to seal them in place. If you are a belt and braces type guy, you can carry a standard H4 bulb under the seat and if shit happens (typically the power line from the battery to the ballasts being too skinny and/or a connector coming loose) you can have it fitted and be on your way in 5 minutes, no tools required. Re: HID Headlights - mark g - 27-07-15 Spot on info Paul, do you think it would be worth going down the HID Projector route or are the HID Bulb conversion good enough
Re: HID Headlights - PaulSmith - 28-07-15 I presume you are talking about replacing the reflectors and not just adding running lights. Projector or bulb conversion makes no difference to the light on the road so the choice would be for other reasons. As I said, the bulb conversion can be done on the cheap, is completely reversible and is quite hard to get wrong. The projector option looks really cool if it is done right but is expensive, permanent and not easy to get a professional finish. That said, I would seriously consider it if there is no way to do the bulb conversion on my next bike. One thing I forgot to mention is that you should pick up some LED side lights. The originals start to look a really naff tobacco stain colour when the HIDs are fitted. Re: HID Headlights - mark g - 28-07-15 Cheers for that Paul, I've already ordered the LED side lights
Re: HID Headlights - b1k3rdude - 28-07-15 It's been said before, H4 HID kits just don't provide an even remotely accurate beam pattern. On dip, yeah loads of light but the splash/spill will just dangerously dazzel every other road user. And hi beam is a 50/50 lottery as to wither it was actually project a beam on the road on front or just splash all over the place. And no it wont pass an MOT its an instant fail. If you want more light and not dazzle other road users you could do what I have done - - http://www.bikevis.com/forum/index.php?topic=1088.0 Just tow them down a bit so as to be no higher than the top of the dip beam and you good to go, these LED spots only use 10W/0.66A each and the pair put out the same amount of light a a single HID bulb (1800lumens). The only issue is price @£95 per pair, but that said I have a set ofn my Bandit and Fazer and both sets are 2+ years old. HID kits I bought in the past barely make it paste a year before either the bulb or the ballast dies. ![]() ![]() Here is a BMW rider with a set of CREE's https://www.youtube.com/watch?v=oQnTpifvitg There are other makes of CREE based spotlights, so your not limited to Bikviz - - https://www.google.co.uk/search?q=cree+motorcycle+spot+lights&ie=utf-8&oe=utf-8&gws_rd=cr&ei=u-q3VZLOHYrWeLe8v-AP Re: HID Headlights - PaulSmith - 29-07-15 (28-07-15, 09:48 PM)b1k3rdude link Wrote: It's been said before, H4 HID kits just don't provide an even remotely accurate beam pattern. ... It has been said before, and it was wrong before, and if you say it again, you will be wrong, again. The reflector reflects the light from a point source in a pattern decided by its designers. It does not know or care how that light is generated, only if it is in the right place. You can use a tungsten, halogen, bi-xenon or HID bulbs, fuck you can even use a carbide lamp if you can find a way to not melt the plastic, and it will not make a difference to the pattern of light reflected. Re: HID Headlights - Stormin - 30-07-15 HID's are illegal on any vehicle unless they are self levelling. Instant fail for MOT and fixed penalty from the long arm of the law. Been there,done it and paid the fine!! Re: HID Headlights - PaulSmith - 30-07-15 (30-07-15, 01:31 AM)Stormin link Wrote: HID's are illegal on any vehicle unless they are self levelling. Instant fail for MOT and fixed penalty from the long arm of the law. Been there,done it and paid the fine!!Wrong, wrong and wrong. Who comes up with these things? I verified this with a sargeant I know in the Met who is currently serving in traffic; The long arm of the law do not and can not issue fixed penalty notices for HID headlights that are not fitted with self-levelling mechanisms because the long arm of the law are not trained to be road-side vehicle inspectors capable of determining if you actually have a self-levelling system fitted let alone determine whether or not it is working. Self levelling systems are not specifically mentioned for motorbikes in the MOT manuals but for all vehicles, IF fitted, it needs to work. Quote:Vehicles equipped with High Intensity Discharge (HID) or LED dipped beam headlamps may be fitted with headlamp washers and a suspension or headlamp self levelling system.Where such systems are fitted, they must work; however, it is accepted that it may not be possible to readily determine the functioning of self levelling systems. In such cases, the benefit of the doubt must be given.So if they don't have to be there, and even if they are, MOT testers cant tell if they are working, how the foc are the plod expected to be able to? The third popular old wives tale concerns scatter and sparkle when HID's are fitted. The beam patterns required are described in http://www.motuk.co.uk/manual_180.htm and they make no reference to sparkle. As stated before, a reflector is designed so that light coming from a particular point is reflected to produce the desired pattern. Any light outside that pattern is a result of imperfections in production and errors and compromises in the design. How the light is generated DOES NOT AFFECT THE PATTERN OR THE SCATTER. In other words, your reflector will pass an MOT, or it will fail it, regardless of the bulb that is in it. Back to the plod. The plod are able to issue fixed penalty notices if your headlights are clearly pointing in the wrong direction or if they have a blueish tinge. The motorcycle requirements of the MOT: http://www.motuk.co.uk/mcmanual_120.htm specify that the light source FOR THE DIPPED BEAM be white or yellow. The term 'white' is not strictly defined in the document so is left to the testers discretion. White light is generally considered by scientists to be between 2.5k and 10k with the daylight being between 5 and 6.5k Kelvin. Light over 6k has a visible blueish tinge and may attract the attention of the boys in blue. consider yourself warned. At the end of the day, if you are unlucky enough to fail an MOT for having HIDs fitted, or have any other problem with them at all, it takes less then five minutes to unplug them and replace one bulb with the traditional H4 bulb you carry under your seat. No tools required. The advantages of having HID over traditional Halogen bulbs are:
Re: HID Headlights - Stormin - 30-07-15 Thanks for the essay. Your plod are obviously more relaxed than our cops here but it's still a MOT failure as far as our Government run system goes which basically boils down to no two Police Forces are the same. Maybe I should have made it clear that I'm on the opposite side of the Irish Channel Re: HID Headlights - mark g - 30-07-15 Cheers once more for the info Paul Smith, the cree spot lights in previous post look great but not my cup of tea. Paul, what lit did you end up getting for your bike ? I've been looking at car ones on ebay with slim ballast etc but not sure if they will fit etc. Re: HID Headlights - PaulSmith - 31-07-15 Sorry Stormin, maybe I was the one not being clear. Those are the UK MOT documents I linked to, not the Irish ones, and they clearly state that self-levelling systems are optional, and even if fitted they may not be possible to test. If you have any information the contradicts that , please post it. I cant think of any bikes with HID lights as standard but you will also notice that the self-levelling mechanism requirements apply to LED as well as HID, so they apply to the new Yamaha Tracer, which does not have any special mechanism. And I don't see plod queueing up to ticket them? The sargeant in question is in the London Metropolitan Police, and has had a number of different roles in traffic. He is currently involved in the commercial stuff as one of the evil bastards that check trucks and lorries are compliant. I am inclined to believe him especially when he gives the reasons that link to the evidence from the MOT documents and offers other ways that he could ticket you. If you did get a fixed point ticket, what was it for? He suggested that it was probably a CU20 "Causing or likely to cause danger by reason of use of unsuitable vehicle or using a vehicle with parts or accessories (excluding brakes, steering or tyres) in a dangerous condition" in which case the particulars should have detailed the offence that needed correcting so his buddy could give you a bollocking if you were stopped for it again. I would guess your bulbs were "inappropriatly coloured potentially causing confusion with an emergency vehicle" (ie the bulbs were blue) or they were just badly adjusted. It was not because you didn't have a self-levelling mechanism, but again, prove me wrong. Re: HID Headlights - PaulSmith - 31-07-15 (30-07-15, 09:16 PM)mark g link Wrote: Cheers once more for the info Paul Smith, the cree spot lights in previous post look great but not my cup of tea. Paul, what lit did you end up getting for your bike ? I've been looking at car ones on ebay with slim ballast etc but not sure if they will fit etc.Bloody hell! I have just seen the kit I fitted for under a tenner! How the hell do that do that? http://www.ebay.ie/itm/2pcs-Pair-35W-55W-75W-Xenon-HID-OEM-Replacement-Bulbs-car-Headlight-Lamp-H4-3-/271930374963?pt=LH_DefaultDomain_3&var=&hash=item3f50503b33 Get the 35W H4-3 5000k bulbs with slimline ballasts and you cant go wrong. (I have just ordered a spare set I will keep on the shelf or fit to my daughters car or something.) I was going to recommend something like the HIDS4U kit http://www.hids4u.co.uk/h4-hids4u-slim-35w-hid-xenon-conversion-motorcycles.html or the http://www.hids4u.co.uk/h4-35w-slim-proplus-bi-xenon-hid-conversion-kit.html but at £45 per bulb, I find it hard to justify. Re: HID Headlights - b1k3rdude - 01-08-15 (29-07-15, 10:42 AM)PaulSmith link Wrote: The reflector reflects the light from a point source in a pattern decided by its designers. It does not know or care how that light is generated, only if it is in the right place.And that's the whole point, all retro-fit HID kit's on the market today don't have the arc in the right position. And the HID kits with mechanical hi/lo bulbs are the worse offenders -
(31-07-15, 11:39 AM)PaulSmith link Wrote: Bloody hell! I have just seen the kit I fitted for under a tenner! How the hell do that do that? http://www.ebay.ie/itm/2pcs-Pair-35W-55W-75W-Xenon-HID-OEM-Replacement-Bulbs-car-Headlight-Lamp-H4-3-/271930374963?pt=LH_DefaultDomain_3&var=&hash=item3f50503b33Case in point -
Re: HID Headlights - mark g - 01-08-15 So what about the HID Projector kits, expensive and a bit more work to do but has anybody tried these? https://www.youtube.com/watch?v=r3p5jedQ https://www.retrofitlab.com/en/hid-projector-kit/bi-xenon-mini-d2s-30-twin-kit-2.html Re: HID Headlights - b1k3rdude - 02-08-15 (01-08-15, 08:00 PM)mark g link Wrote: https://www.retrofitlab.com/en/hid-projector-kit/bi-xenon-mini-d2s-30-twin-kit-2.htmlThe youtube link isn't working. And I have considered doing this as it will give you perfect dip and hi beam patterns, you can send them your headlight and they will fit the kit for you - or can you can do it yourself. The only 'issue' I can foresee with these kits is if the back of the DS2 bulb dosent seal against the rubber covers your going to get condensation inside the headlight housing. I can tell from the photo's if the length/width of the rear of the DS2 bulbs is the same as the oem Halogens . So Im gonna drop them an email... ! No longer available Re: HID Headlights - mark g - 02-08-15 I've had a few email conversation with them already, they seems very helpful and are quick to respond which makes a nice change, I'm not sure what to do yet, would go with the projector set-up straight away if they were a bit cheaper........I'll probably try some bulbs first just to satisfy my curiosity :lol Re: HID Headlights - PaulSmith - 04-08-15 (01-08-15, 10:34 AM)b1k3rdude link Wrote: And that's the whole point, all retro-fit HID kit's on the market today don't have the arc in the right position. And the HID kits with mechanical hi/lo bulbs are the worse offenders -"all retro-fit HID kit's on the market today don't have the arc in the right position." Really! :eek All of them? Wow, that is a big claim. I mean, who would have thought that companies like Phillips and Osram wouldn't know how to make a H4 bulb properly? Thank goodness there are people like you on the internet to put them right. So what is the correct position for the light source? Just so I can check my own bulbs are OK? |
