knocking through foot peg?? - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: knocking through foot peg?? (/showthread.php?tid=73328) |
knocking through foot peg?? - mr wayneker - 26-07-15 hi all went for a ride to south wales yesterday on the way back..at Bristol she developed a slight vibration then a knock on which was coming through the foot pegs...at that point I pull in when coming to a stop there was a squeak coming from one of the wheels..well that's where I thought it was coming from almost like a dry bearing and the knock could be a missing ball bearing????? so set off doing 60mph towards Exeter...get to Exeter on the slip road change down to 1st...pull off and it then sounded like the chain was rubbing on the sprocket as I was going through the gears so then thought it must be the front sprocket coming undone...got here home took the front sprocket cover off nothing hasn't moved no sign of movement..so I got back on went around the block with no helmet on and the squeak and what sounds like crunching was still there so I have taken the rear wheel off late last night... going to check bearings...but don't think its going to be that simple???? :'( could it be behind the front sprocket don't know whats in there yet...but would think it involves all the gearing release bearings and things like that.....I hope I don't have to go in there.... the squeak is like a dry bearing noise.... [smg id=2639 type=preview align=center caption="20150725 202822"] [smg id=2640 type=preview align=center caption="20150725 202834"] oh and I snapped a bolt yippy Re: knocking through foot peg?? - mr wayneker - 26-07-15 searching on e#ay for bearing kits now any advice??? on kits Re: knocking through foot peg?? - darrsi - 26-07-15 A knocking feel through the left footpeg is normally caused by stiff chain links. Basically they get dried out through lack of attention and just seize up. Sometimes you can try and work them free with pliers and plenty of oil but i've normally found that once they start seizing they're on their way out. If you put the wheel and chain back on with a bit of tension, have a look at the lower level of the chain while slowly moving the wheel around by hand. Stiff chain links have a tendency to jam in a very slightly diagonal position, so will stand out to all the other horizontal links. It may just be the one link or it could be several. If it's more than one then personally i'd just change it'cos it'll never be decent again. Chains do need proper care and attention, especially during winter or these random monsoons that we get, and will need a proper clean with a brush every now and then, but must be kept well lubedall the time otherwise even a new chain can dry out quickly and be knackered in no time. Re: knocking through foot peg?? - HarryHornby - 26-07-15 +1 for chain. I had this on my FZS600, knocking through foot peg. Changed chain and sprockets and it went. Re: knocking through foot peg?? - unfazed - 26-07-15 Definitely worn chain and/or sprockets if all the bearings check out Re: knocking through foot peg?? - mr wayneker - 26-07-15 so whats the chain and sprocket of choice and what chain tool will I need to buy????? Re: knocking through foot peg?? - darrsi - 26-07-15 D.I.D. sprocket/chain kit on Ebay is tried and tested. Re: knocking through foot peg?? - mr wayneker - 28-07-15 ok so the knocking was the rear bearing on the sprocket carrier....now the knocking has stopped :rollin and crunching |
