Can't get neutral - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: Can't get neutral (/showthread.php?tid=73244) |
Can't get neutral - HJFazer - 17-07-15 Hey, so assistance needed please. Even with clutch in I can't get neutral and it won't start in gear. I think the cable must be too stretched and do not fully engaging causing the above. Does that sound right? Any thoughts on fixing it? Have changed the levers a few weeks ago so night try the old one in the hope it pulls it enough. Help appreciated, Haydn Re: Can't get neutral - His Dudeness - 17-07-15 Have you tried rocking it back and forward while changing gears? Is your chain very slack? Re: Can't get neutral - HJFazer - 17-07-15 Got it in eventually. Chain is within the tolerance but at the lose end of it. Think it might need a new cable as it's pretty slack and I'll tighten the chain as well. Cheers Re: Can't get neutral - unfazed - 17-07-15 (17-07-15, 09:20 PM)HJFazer link Wrote: Got it in eventually. Chain is within the tolerance but at the lose end of it. Check the clutch adjustment at the Sprocket cover side. Re: Can't get neutral - darrsi - 17-07-15 (17-07-15, 09:42 PM)unfazed link Wrote: [quote author=HJFazer link=topic=17677.msg204129#msg204129 date=1437164428] +1 to that. Lower end first then tweak at the lever end. Check the clutch adjustment at the Sprocket cover side. [/quote] Re: Can't get neutral - HJFazer - 17-07-15 Cheers guys, will have a play tomorrow Re: Can't get neutral - Jules-C - 18-07-15 Check the sprocket cover screws are tight. They have been known to unscrew giving the same symptoms as a stretched cable |
