Gen 1 Headlights, how many on dip? - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: Fazer 1000/FZ1 corner (https://foc-u.co.uk/mybb/forumdisplay.php?fid=75) +--- Thread: Gen 1 Headlights, how many on dip? (/showthread.php?tid=73210) Pages:
Gen 1 Headlights, how many on dip? - harrness - 13-07-15 A little help please, I have just mot'd my 2001 gen 1 Fazer 1000. the guy said there is a problem with my headlights. I have mot'd it twice before with ne problem, nothing has changed, so I am confused. the guy said only 1 light should be on, when on dipped beam. He also said the lights were dipping to wrong side. anyone help with what should be happening on dip? many thanks harrness Re: Gen 1 Headlights, how many on dip? - slappy - 13-07-15 Both lights should be on when on dipped beam. If it is dipping to the wrong side is it an import? Re: Gen 1 Headlights, how many on dip? - harrness - 13-07-15 (13-07-15, 08:32 PM)slappy link Wrote: Both lights should be on when on dipped beam. cheers for the quick response. no its not an import and has passed mot, without issues for years, is there a way to identify if the headlights are correct? Re: Gen 1 Headlights, how many on dip? - slappy - 13-07-15 (13-07-15, 08:34 PM)harrness link Wrote: [quote author=slappy link=topic=17643.msg203624#msg203624 date=1436815967] cheers for the quick response. no its not an import and has passed mot, without issues for years, is there a way to identify if the headlights are correct? [/quote] Don't personally know how to tell if the lights are correct but hopefully someone else on here will Re: Gen 1 Headlights, how many on dip? - tomlinscote - 13-07-15 Had my 2004 gen 1 from new and both lamps are on when on dipped beam. No problem so far with MOTs but next one is in august! I have always thought my beam just goes up and down rather than up and right ( and therefore down and left ) but maybe my eyesight is crap or I am always too close to the wall I am using? Never really use full beam on the road as not out much at proper night time on unlit roads. Re: Gen 1 Headlights, how many on dip? - harrness - 13-07-15 (13-07-15, 08:53 PM)tomlinscote link Wrote: Had my 2004 gen 1 from new and both lamps are on when on dipped beam. No problem so far with MOTs but next one is in august! I have always thought my beam just goes up and down rather than up and right ( and therefore down and left ) but maybe my eyesight is crap or I am always too close to the wall I am using? Never really use full beam on the road as not out much at proper night time on unlit roads.. could you have a look at the marking on your headlights please? i would like to check if mine are correct. i dont understand how my bike has passed previous mot's Re: Gen 1 Headlights, how many on dip? - sadlonelygit - 13-07-15 ![]() you can adjust the throw of the light however, but it's definately both dipped.............funny because last year she failed as only 1 was working! Re: Gen 1 Headlights, how many on dip? - characticus - 13-07-15 2004 model both on. I've just checked the wiring diagram for 2001-2003 & the one for 2003 onwards. Bulbs are wired in parallel with no possibility to switch one off by itself. US model is the same too. Re: Gen 1 Headlights, how many on dip? - esetest - 13-07-15 I have a 2002 Foxeye , both lights are on when dipped and obviously brighter on high beam , did you use the same garage for previous MOT , perhaps try another garage . Re: Gen 1 Headlights, how many on dip? - harrness - 13-07-15 (13-07-15, 09:15 PM)sadlonelygit link Wrote:is it easy to adjust the pattern? Re: Gen 1 Headlights, how many on dip? - harrness - 13-07-15 (13-07-15, 09:35 PM)esetest link Wrote: I have a 2002 Foxeye , both lights are on when dipped and obviously brighter on high beam , did you use the same garage for previous MOT , perhaps try another garage .i am in belfast, we have to use DVA centres, bloody jobs worth for some of them Re: Gen 1 Headlights, how many on dip? - harrness - 13-07-15 There is an E13 marked on both lights, some people on the web say this is on their uk bikes Re: Gen 1 Headlights, how many on dip? - tomlinscote - 13-07-15 Will have a look at the lights tomorrow, Harness. As to the MOT question, I used to have a 205 GTi with a big bore exhaust, passed its MOTs at the same place for three years then one year failed due to excess noise, I told the new guy it had passed before he said nothing but opened his MOT manual to a page which simply said "in the opinion of the examiner...." so we don't really have much chance do we!! Re: Gen 1 Headlights, how many on dip? - PieEater - 14-07-15 As others have said both lights operate on dipped beam on this and many bikes so the tester doesn't know what they are talking about. I would ask to speak with their supervisor and explain that there has never been an issue previously with the throw of the lights and explain that whilst you are happy to adjust the beams you want to make sure that the tester is not mistaken about this as well, so you don't end up having to adjust them back again for next years test. If you end up having to adjust them, both lights are adjusted independently so you need to be sure which one needs adjusting (if not both). There are 2 adjusters, top inner corner for horizontal adjustment and bottom outer corner for vertical adjustment. For the left hand beam, turning the top inner adjuster anti-clockwise moves the beam to the right and clockwise moves it to the left. For the right hand beam turning the top inner adjuster clockwise moves the beam to the right and anti-clockwise to the left. Re: Gen 1 Headlights, how many on dip? - tomlinscote - 14-07-15 Here are, as promised, the markings on the headlights.... 02HC/RPL 02A E13 (in a circle) 125 9914 STANLEY P1772 Each light has an arrow pointing left or right but the writing seems to be the same on each, I may have confused some of the letters etc as left my glasses at work!! I agree with pieeater you can ask for a second opinion, it depends on how well you get on with the test centre as they can all say it was in the opinion of the tester as a catch all excuse. Re: Gen 1 Headlights, how many on dip? - PieEater - 14-07-15 Following from Tomlinscote I found this article that explains the markings - http://www.danielsternlighting.com/tech/lights/codes/codes.html Between the first 2 lines of text on the lens you should have an arrow marking that indicates the throw of the lights. In front of the bike, looking at the markings the arrow should be pointing to the right, when you're sat on the bike the arrow (and beam throw) will be pointing to the left. If the arrow is pointing to the left as you look at it and the right when you're sat on the bike then you have lights designed for right hand road use. I don't think you can adjust right hand use lights for left hand use so if you do have these you'll need to replace them. If you have the correct lights then the tester is an idiot and you really should ask to speak with his supervisor so they can make sure he is properly educated and doesn't continue to needlessly fail other bikes. Re: Gen 1 Headlights, how many on dip? - PaulSmith - 14-07-15 MOT manuals are published online here: https://www.gov.uk/topic/mot/manuals Motorbikes are here: MOT inspection manual for class 1 and 2 vehicles: http://www.motinfo.gov.uk/htdocs/m1i00000001.htm Lighting section: http://www.motinfo.gov.uk/htdocs/m1s01000201.htm Subsection text: Quote:Twin headlamp systems:On twin headlamp systems only one or both headlamps may need to be illuminated for either dipped or main beam. Each headlamp that can be illuminated on dipped beam must meet the requirement for dipped beam headlamps. Twin headlamps must be mounted either one above the other or symmetrically without regard to any sidecar and not more than 200mm apart measured from the edge of the reflecting surface. The tester should advise if both headlights should illuminate for eitherfunction and only one does so. So very clearly, two headlight setup are legal and normal. Re: Gen 1 Headlights, how many on dip? - PaulSmith - 14-07-15 Follow up: From the same manual: Reasons for rejection, 2.a) "does not have at least one headlamp which illuminates when selected on: (i)dipped beam" Notice that it says "at least one" not "only one"! Re: Gen 1 Headlights, how many on dip? - harrness - 14-07-15 Thanks guys the markings on mine are 02HC/RPL 02A E13 in circle 125 9913 Stanley P1606 the arrow on the left light (standing in front of bike) points left (into oncoming traffic) the arrow on the right points to the right (kerb side). looks like mine is wrong, dont understand, I checked frame number with Yamaha UK, they say its a UK bike.. thinks its time for a beer or 2 Re: Gen 1 Headlights, how many on dip? - PieEater - 14-07-15 First cross eyed Fazer I've heard of, the one on the left must have been replaced at some point with an incorrect part. |
