Gen 1 exup valve - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: For Sale & Wanted (https://foc-u.co.uk/mybb/forumdisplay.php?fid=80) +--- Thread: Gen 1 exup valve (/showthread.php?tid=73162) |
Gen 1 exup valve - Tuckerhauser - 09-07-15 Know they are like hens teeth but worth a try;-) after a exup valve for my 2004 fazer valve that's fitted to mine currently rattles like hell end is worn Thanks Re: Gen 1 exup valve - devilsyam - 09-07-15 Easy fix local engineering company ask they to turn down end and make a bush I had mine turned down and used a ball race from a model car worked fine Re: Gen 1 exup valve - Tuckerhauser - 09-07-15 Cheers I'll look in to that, I thought about something like that earlier but was concerned about the material to use. Something like this http://www.ebay.co.uk/itm/391035683580 Re: Gen 1 exup valve - devilsyam - 09-07-15 Open ball bearing can take the heat Re: Gen 1 exup valve - RMT1983 - 09-07-15 Is it just the Arm Shaft that you need? Re: Gen 1 exup valve - Tuckerhauser - 09-07-15 only need this bit that hangs in the exhaust "the cradle" bit ![]() The ends of the above part are worn causing it to rattle Have the cam, spacers mount etc Thanks This is bit I need Re: Gen 1 exup valve - b1k3rdude - 10-07-15 Thats the actual valve, and doesn't look that worn. Have you got a better shot so we can see where the wear is? At a guess Im betting your missing the small spacer that goes on the end that inserts into the hole on the inside the headers, part 13 (90387106u7) ![]() ![]() And regarding the bearings in the end-plate and the headers these are phosphor-bronze, I very much dought you can put normal ball based bearings in there due to the heat 200-400c. For a start the great in them would be burnt away, then there the issue of different expansion level of the balls and the shells. On while we are on the subject, I would strong suggest replacing the cover and plate bolts (number 7, 18) with either Stainless or titainium (I went for Ti, and I've had them for years just moving from one bike to the next) Re: Gen 1 exup valve - Tuckerhauser - 10-07-15 Cheers for the reply, I have the spacer part 13 I'll get a better shot of the ends tonight when I get home. That was my concern the material to make the bushes out, and my fear with using bearings Re: Gen 1 exup valve - devilsyam - 10-07-15 Gonna spell it wrong but phos-fur-bronze Re: Gen 1 exup valve - Tuckerhauser - 10-07-15 ![]() Re: Gen 1 exup valve - Tuckerhauser - 10-07-15
Re: Gen 1 exup valve - b1k3rdude - 10-07-15 Ok, there is wear there. But with all the spacers in-place and the correct amount of slack set on the pully cables you shouldn't hear much of any rattle. Re: Gen 1 exup valve - unfazed - 10-07-15 (09-07-15, 12:30 PM)Tuckerhauser link Wrote: Know they are like hens teeth but worth a try;-) Did you check the wear on the bushes and the housing? Wear on any of these will cause the valve to rattle also. I had to replace the bushes on mine after 25000 miles. Re: Gen 1 exup valve - Tuckerhauser - 11-07-15 Wear on the bushes doesn't seem too bad considering 47,000 miles Deffo slack on the valve spindle, lots of "wobble" and it's just amplifies thru the can Tried adjusting but was the same, there's a couple of machine shops local to me will have a pop in this week and see wots possible. Re: Gen 1 exup valve - unfazed - 12-07-15 Knock out the bushes and take them with you, they should be able to machine new ones to suit the valve Re: Gen 1 exup valve - eddie - 12-07-15 Ear plugs cures rattles.......or if you're on a goldwing turn up radio |
