Electrical speedo cable from front wheel? - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: Electrical speedo cable from front wheel? (/showthread.php?tid=73123) |
Electrical speedo cable from front wheel? - Decoke Dave - 05-07-15 On an 02 fox eye does anyone know what the speedo plug and socket in the plastic box under the tank looks like? Could someone describe it. I.E. shape and colour, I think my one may have a non standard one fitted. Many Thanks! Re: Electrical speedo cable from front wheel? - Jules-C - 06-07-15 Not taken tank off to check but I think it is a different style from anything else on the bike. Normally if the plug only needs 3 contacts they use a square 4 pin connector but leave one of the pins out but the speedo drive one has the 3 pins in a triangle with no space for a fourth pin. Re: Electrical speedo cable from front wheel? - Lumpy - 06-07-15 rounded triangle. Can be a beggar to separate Re: Electrical speedo cable from front wheel? - Decoke Dave - 06-07-15 Many Thanks! I was afraid my one was botched to fit a box to cheat the K.P.H. speedo to M.P.H. But the cheat box has the correct original plug and socket on each end and simply links in! Well impressed, easily removed if required and all remains standard. |
