Flashing ABS light - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: Fazer 1000/FZ1 corner (https://foc-u.co.uk/mybb/forumdisplay.php?fid=75) +--- Thread: Flashing ABS light (/showthread.php?tid=73121) |
Flashing ABS light - Stewie - 05-07-15 When I was riding yesterday the ABS light started flashing at me. I pulled over turned it off and back on again and it was ok for a while but then it started again and reset again. I was not riding stupid, when it happened, or doing really heavy breaking and the ABS did function with the light flashing, I tried to lock up the rear and I could feel it pulsing. The flash was on for about a second and then off for about a second as well if this helps. I have checked the manuals, service and owners, and there is nothing I can see. I have also checked t'Internet and there is nothing really about my issue. Re: Flashing ABS light - pilninggas - 05-07-15 Worth a read: http://www.fjrowners.com/forums/9-fjr-technical/7702-abs-light-flashing.html Re: Flashing ABS light - Stewie - 05-07-15 (05-07-15, 05:26 PM)pilninggas link Wrote: Worth a read: Thanks for that. With other trolling I have a list of items to check ABS sensors brake pedal switchs fluid levels Bearings and axles I might have to check my new lights and flashers also. Re: Flashing ABS light - Stewie - 06-07-15 I found the problem after not too much searching. Brake light had blown so there was low load on the circuit which set the warning light off. |
