Sprockets - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: Sprockets (/showthread.php?tid=73077) |
Sprockets - Tommyk - 30-06-15 Hi people I've been doing some longer distances and decided I wanna bring my Cruising revs down would I be better off Changing the front rear or both sprockets thanks Re: Sprockets - paulchucky - 30-06-15 depends on what you want ? but change both sprockets and chain what sort of riding you doing and what are you wanting to achieve? Re: Sprockets - Tommyk - 30-06-15 Hi Paul cheers for the reply I've had some advice since I posted all I want is a little less revs when cruising on the motorway seems that one tooth bigger at the front is what I need not fussed about the slight loss of acceleration thanks again Re: Sprockets - Val - 01-07-15 (30-06-15, 09:06 PM)Tommyk link Wrote: Hi Paul cheers for the reply I've had some advice since I posted all I want is a little less revs when cruising on the motorway seems that one tooth bigger at the front is what I need not fussed about the slight loss of acceleration thanks again One tooth plus front means about %6 less rpms which is about -200 to -500 rpms. See this for details about speeds and RPMs - http://www.gearingcommander.com/ Re: Sprockets - paulchucky - 01-07-15 (30-06-15, 09:06 PM)Tommyk link Wrote: Hi Paul cheers for the reply I've had some advice since I posted all I want is a little less revs when cruising on the motorway seems that one tooth bigger at the front is what I need not fussed about the slight loss of acceleration thanks again up 1 on front will bring revs down slightly will also slow acceleration a little bear this in mind :? if your doing 90% motorway miles fine but if your doing a lot of traffic work you`ll be jumping up n down that gear lever like a pogo stick speed linit is 70mph so you get away with 80mph on a motorway not 100mph + so why not just ease off the throttle abit :lol Re: Sprockets - Val - 01-07-15 (01-07-15, 07:39 AM)paulchucky link Wrote: [quote author=Tommyk link=topic=17509.msg201784#msg201784 date=1435694805] up 1 on front will bring revs down slightly will also slow acceleration a little bear this in mind :? if your doing 90% motorway miles fine but if your doing a lot of traffic work you`ll be jumping up n down that gear lever like a pogo stick speed linit is 70mph [size=1em] so you get away with 80mph on a motorway not 100mph +[/size] [size=1em]so why not just ease off the throttle abit [/size] :lol [/quote] Exactly, initially I was also thinking to go 17/47, but after some thoughts I've decided that I do not do too much motorway miles. Because of my traffic work I have gone the other route 14/49 :lol Re: Sprockets - Lumpy - 06-07-15 plus 1 on the front for me, been using it for 50 000 miles. Can pull the wheel forward enough for a new tyre to scrape the hugger though. Standard chain. It's the equivalent of minus 3 on the rear. Much better. [table] [tr] [td]110 link[/td] [td][/td] [td][/td] [td][/td] [td][/td] [td][/td] [/tr] [tr] [td][/td] [td][/td] [td][/td] [td][/td] [td][/td] [td][/td] [/tr] [tr] [td][/td] [td]Front[/td] [td]Rear[/td] [td]Ratio[/td] [td]rpm@100[/td] [td]8000rpm[/td] [/tr] [tr] [td]standard[/td] [td]15[/td] [td]48[/td] [td]3.2[/td] [td]8533.33333[/td] [td]93.75[/td] [/tr] [tr] [td]now[/td] [td]16[/td] [td]48[/td] [td]3[/td] [td]8000[/td] [td]100[/td] [/tr] [tr] [td][/td] [td]15[/td] [td]44[/td] [td]2.933333[/td] [td]7822.22222[/td] [td]102.27[/td] [/tr] [tr] [td][/td] [td]16[/td] [td]46[/td] [td]2.875[/td] [td]7666.66667[/td] [td]104.35[/td] [/tr] [tr] [td][/td] [td]16[/td] [td]45[/td] [td]2.8125[/td] [td]7500[/td] [td]106.67[/td] [/tr] [tr] [td][/td] [td]16[/td] [td]44[/td] [td]2.75[/td] [td]7333.33333[/td] [td]109.09[/td] [/tr][/table] Re: Sprockets - Millietant - 10-07-15 Typed this here before I realised I wasn't u reading the thread Val started on sprockets "I'm confused Val, looking at the gearing commander, all you've done is effectively to make your new 6th gear the Sam as your old 5th, your new 5 th gear is your old 4th and your new 4th is your old 3rd. With the changes to 1st and 2nd gear ratio's I can only assume you're going drag racing - and you don't care about fuel economy. To my simple mind, just by never going above 5th gear, you'd have pretty much the same effect, without spending any money on sprockets/chain etc. Like I say, I'm confused - some will think me a numbskull, but I just don't understand changing the gearing this way, unless the bike is so grossly over geared so that it won't pull top gear (which isn't the case on the Fazer)". for our Fazer, when it's time to replace the chain, I'm going up one tooth on the front sprocket and down two teeth on the rear - can keep standard length chain. |
