Strange noise coming from sprocket cover/gearbox - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: General (https://foc-u.co.uk/mybb/forumdisplay.php?fid=65) +--- Forum: General (https://foc-u.co.uk/mybb/forumdisplay.php?fid=69) +--- Thread: Strange noise coming from sprocket cover/gearbox (/showthread.php?tid=73070) |
Strange noise coming from sprocket cover/gearbox - chunk166 - 29-06-15 For a few weeks now i have been getting a grinding/clicking sound coming from the sprocket cover area, It would disappear as i got faster. But tonight i decided to have a look to see if i could find anything,apart from the casing being covered in crap/chain lube i checked to see if the gearbox/drive had any movement but there was none!! I then notice that the sprocket had started to hook a little? I knew i had a spare one so i put it on but it was only a 14t put it all back together & now the noise has gone?? Still got what looks like the 9mm nut on it & managed to get it off quite easily?? Anyway! I think it's now a lot better with a 14t instead of a 15t sprocket. ![]() Just thought i would share my findings with you all :lol :lol :lol Ray Re: Strange noise coming from sprocket cover/gearbox - darrsi - 29-06-15 Gonna hazard a guess your bearings need cleaning out/greasing in your sprocket cover. Re: Strange noise coming from sprocket cover/gearbox - darrsi - 29-06-15 http://foc-u.co.uk/index.php/topic,10124.msg105622.html#msg105622 Re: Strange noise coming from sprocket cover/gearbox - chunk166 - 29-06-15 Just gave it a good clean out & changed the sprocket, feel/rides better
Re: Strange noise coming from sprocket cover/gearbox - darrsi - 29-06-15 You're explaining clicking bearings though, I had the same, did you grease them up? Re: Strange noise coming from sprocket cover/gearbox - Fazerider - 30-06-15 Assuming those are Australian interrogatives: yes, a hooked sprocket is noisier than a new one and yes, the 9mm nut does come off easily. :rolleyes Re: Strange noise coming from sprocket cover/gearbox - chunk166 - 30-06-15 Darrsi, Sorry I might of confused you? The clicking/grinding sound was coming from the sprocket, I initially thought it might of been the bearings on the spline for the sprocket but it turned to hooked teeth!!!! :lol Re: Strange noise coming from sprocket cover/gearbox - darrsi - 01-07-15 (30-06-15, 10:07 PM)chunk166 link Wrote: Darrsi, Sorry I might of confused you? The clicking/grinding sound was coming from the sprocket, I initially thought it might of been the bearings on the spline for the sprocket but it turned to hooked teeth!!!! :lol I'm easily confused. :lol An offset rear wheel / misaligned chain can cause that noise as well, for the record. If you had hooked teeth on the sprocket anyway then it obviously needed changing so no harm done, but if the wheel moves a tad out of line the chain will crunch and grind if it's not straight. |
