Fz misfiring... - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: Fazer 1000/FZ1 corner (https://foc-u.co.uk/mybb/forumdisplay.php?fid=75) +--- Thread: Fz misfiring... (/showthread.php?tid=73060) |
Fz misfiring... - Mike01 - 29-06-15 Morning. So the bike has been fine for the short time i have owned it and nearly 1k miles i have done so far... Last used it Saturday with no problems, got it out of garage an hour or so ago, started fine, ticked over fine for few mins then after 500 yards or so of very slow riding it started to misfire.. Bliped the throttle a few times but it would not clear :\ So its back in my garage and i had to use the car on this beautiful day :'( Will have a look tonight when i get home, will start with leads and plugs... Is there a common problem i should check for?? Thanks. Re: Fz misfiring... - slappy - 29-06-15 Check every eletrical connection you can get at, pull them apart and check for corrosion. Fuel filter and air filter ok? I assume there is petrol in tank
Re: Fz misfiring... - devilsyam - 29-06-15 I had this recently on customers bike build prior to strip down for paint was fine after misfired took some advice front mike and clipped 1/4 off each ht lead problem sorted well worked for me Re: Fz misfiring... - Mike01 - 29-06-15 Did a quick google, our US buddies have this a fair bit and mostly falls down to coils. I will have a look later when i get home but yes will check all connections and there is over 1/2 tank fuel Thought the HT leads plugged directly into the caps, not sure if you can cut these down? Mike. Re: Fz misfiring... - Mike01 - 29-06-15 So it's missing on #2, now to work out how to get the lead/caps off.... #space.... Re: Fz misfiring... - Mike01 - 29-06-15 It's not the coil... Swapped that round and 2 still missing... Re: Fz misfiring... - slappy - 29-06-15 (29-06-15, 05:50 PM)Mike01 link Wrote: So it's missing on #2, now to work out how to get the lead/caps off.... #space.... When you have managed that tell me how , I was looking at mine other day and it looks even tighter than the gen1
Re: Fz misfiring... - slappy - 29-06-15 (29-06-15, 06:02 PM)Mike01 link Wrote: It's not the coil... Swapped that round and 2 still missing... Swap plug over Re: Fz misfiring... - Mike01 - 29-06-15 (29-06-15, 06:03 PM)slappy link Wrote: [quote author=Mike01 link=topic=17492.msg201654#msg201654 date=1435596634] When you have managed that tell me how , I was looking at mine other day and it looks even tighter than the gen1[/quote] Fairly easy to be honest, drop rad from mounts, pull down and access from top Re: Fz misfiring... - Mike01 - 29-06-15 ![]() Plugs fooked
Re: Fz misfiring... - slappy - 29-06-15 At least you know the cause of the misfire now, how many miles have they done? Re: Fz misfiring... - Mike01 - 29-06-15 All 12k I would say, just grabbed new set from Halfords.. Re: Fz misfiring... - Mike01 - 29-06-15 New set in and running sweet
