White Tank Behid Rear Shock, What is it? - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: Fazer 1000/FZ1 corner (https://foc-u.co.uk/mybb/forumdisplay.php?fid=75) +--- Thread: White Tank Behid Rear Shock, What is it? (/showthread.php?tid=73026) |
White Tank Behid Rear Shock, What is it? - sox22ufo - 25-06-15 Hi Guys theres a white tank, looks like a water holder behind the rear shock, what is it, as its empty, should there be water in it :eek :eek :eek Re: White Tank Behid Rear Shock, What is it? - mickvp - 25-06-15 It's the expansion tank for the radiator. There's a level on it at the side I'm sure Re: White Tank Behid Rear Shock, What is it? - red98 - 25-06-15 Two lines on the rear face, upper and lower limits, top it up to the high level using a anti freeze mix
Re: White Tank Behid Rear Shock, What is it? - sox22ufo - 25-06-15 Its empty so I'll top it up to the highest level, cheers guys Re: White Tank Behid Rear Shock, What is it? - AyJay - 25-06-15 That's an interesting spot. I've only ever filled the system using the radiator cap under the fairing infill, but the manual says fill the bottle. Can't say it's ever done it any harm though, but I do run the engine with the cap off to let the system bleed for a while. Re: White Tank Behid Rear Shock, What is it? - PieEater - 26-06-15 (25-06-15, 07:22 PM)sox22ufo link Wrote: Its empty so I'll top it up to the highest level, I'd also take off the radiator cap and check the coolant level in the system. Re: White Tank Behid Rear Shock, What is it? - brooker81 - 26-06-15 lol. at this Re: White Tank Behid Rear Shock, What is it? - coppi - 30-06-15 One little addition to all the other replies: Use distilled water only with your antifreeze mix. Keep an eye on your expansion tank, it should not be getting empty - if it does it again then there is a problem. Possibly a leak or, the cooling system is running too hot and boiling, whereby coolant will exit via overflow pipe from e/tank. Re: White Tank Behid Rear Shock, What is it? - FazerFazersson - 30-06-15 And don't forget to check while on the centre stand as a full tank will appear empty while on sidestand. |
