carb vacuum gauge's.....which type is best? - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: General (https://foc-u.co.uk/mybb/forumdisplay.php?fid=65) +--- Forum: General (https://foc-u.co.uk/mybb/forumdisplay.php?fid=69) +--- Thread: carb vacuum gauge's.....which type is best? (/showthread.php?tid=73001) |
carb vacuum gauge's.....which type is best? - mark g - 23-06-15 I've got an old set of the carb tune none mercury gauge's, must be a good few years old now or a bank of 4 separate dial gauge's a better more accurate bet?
Re: carb vacuum gauge's.....which type is best? - slappy - 23-06-15 I have a set of the 4 separate dial gauge type, had them for years , used them plenty of times to balance my bikes and mates bikes and are accurate enough. What makes you think your old gauges are not accurate any more? If you are thinking of replacing your old ones how much do you want to spend is probably the most deciding factor. Re: carb vacuum gauge's.....which type is best? - mark g - 24-06-15 Hi Slappy, mine ain't dial gauges there more like four tubes that sit upright in a little box, they might be fine but my thoughts were a dial gauge just looks more accurate if that makes any sense Re: carb vacuum gauge's.....which type is best? - Grahamm - 24-06-15 (24-06-15, 05:04 AM)mark g link Wrote: my thoughts were a dial gauge just looks more accurate if that makes any sense I've never used one of these, but I'd think that the four tubes ones were better because a) there's no mechanical component (the vacuum has to move a needle which may have some resistance) and b) on the four tubes you can just look straight across and see they're all at the same level, rather than having to check the individual position of each needle on a dial. Re: carb vacuum gauge's.....which type is best? - slappy - 24-06-15 (24-06-15, 12:34 PM)Grahamm link Wrote: [quote author=mark g link=topic=17433.msg200898#msg200898 date=1435118656] I've never used one of these, but I'd think that the four tubes ones were better because a) there's no mechanical component (the vacuum has to move a needle which may have some resistance) and b) on the four tubes you can just look straight across and see they're all at the same level, rather than having to check the individual position of each needle on a dial. [/quote] I would have thought that as well, every time I have used mine I have spent the first five minutes adjusting the dampers to stop the needles flickering. |
