Rear brake pedal adjustment - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: Fazer 1000/FZ1 corner (https://foc-u.co.uk/mybb/forumdisplay.php?fid=75) +--- Thread: Rear brake pedal adjustment (/showthread.php?tid=72993) |
Rear brake pedal adjustment - nick crisp - 22-06-15 FZS1000, is it the same as the gear lever, on splines? It's sitting way too low and I can hardly operate the thing. Re: Rear brake pedal adjustment - slimwilly - 22-06-15 Bend you leg you bloody cripple :lol :lol :lol :lol :lol :lol On our gen 2s there is a adjuster,bolt to extend,retract on the back of the peg pivot,,unless that's just on my giles rearsets ,Just looked at a picture of easytests bike on "what did you do to your bike today" dated 19th june and it looks like on the rear of the brake pedal is a rising adjuster rod,like the gearshifter ,should be easy,,you may too have to adjust the rear brake light switch to match Re: Rear brake pedal adjustment - nick crisp - 22-06-15 Just being lazy asking here really. I'll get a look in daylight tomorrow. I didn't think it was splines :rolleyes Re: Rear brake pedal adjustment - devilsyam - 22-06-15 Behind the brake lever is a clevis pin above that by a rubber boot you will find the adfuster Re: Rear brake pedal adjustment - unfazed - 23-06-15 (22-06-15, 11:03 PM)devilsyam link Wrote: Behind the brake lever is a clevis pin above that by a rubber boot you will find the adfuster Whats an Adfuster? :lol Re: Rear brake pedal adjustment - esetest - 23-06-15 (22-06-15, 10:09 PM)slimwilly link Wrote: Bend you leg you bloody cripple :lol :lol :lol :lol :lol :lolWhen i tried to adjust mine a ccouple of years ago , the brake light wouldn't come on , Victor sorted it at MOT time . Re: Rear brake pedal adjustment - nick crisp - 24-06-15 How on earth do I get to the bottom nut on the ad(f)uster? ![]() Can't get spanners or sockets in there, even if I removed the pin and pedal. I have tried loosening the top nut, depressing the pedal slightly so the bracket isn't resting under spring pressure on the bottom nut, and the nut is more than finger tight still (thread must be gunged up a bit). The length of thread below the nut prevents me from even getting some long nose pliers on the nut from below if I remove the pedal pin. Puzzled :\ (Bet I'm missing something really obvious :rolleyes) Re: Rear brake pedal adjustment - devilsyam - 24-06-15 That's the two obvious ones lift the boot up and there's a 8mm from memory Re: Rear brake pedal adjustment - markie_wales - 24-06-15 (24-06-15, 12:14 PM)nick crisp link Wrote: How on earth do I get to the bottom nut on the ad(f)uster? If it's like most bikes (and my current KTM) the nut will be trapped by the "U" so turning the rod will spin in the nut. cheers Markie Re: Rear brake pedal adjustment - nick crisp - 24-06-15 (24-06-15, 12:37 PM)devilsyam link Wrote: That's the two obvious ones lift the boot up and there's a 8mm from memory Cheers Luke. Pedal height and brake light switch adjusted, satis ![]() (10mm for future reference). |
