Scott oiler oil.... - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: Scott oiler oil.... (/showthread.php?tid=72952) |
Scott oiler oil.... - grizzler - 20-06-15 So i am thinking of fitting a scott oiler to my fzs600. Now the "official" oil is redonkulesly expensive BUT, i am informed that a regular 10w50 will do the job just as well for a fraction of the cost. Question. Is this information reliable??? Re: Scott oiler oil.... - Slaninar - 20-06-15 :book Re: Scott oiler oil.... - NorthWestern - 20-06-15 It's £8 for a bottle that will do probably 20k miles if it's setup right. Engine oils etc seem to make more mess and doesn't wash off as easily Re: Scott oiler oil.... - Dave48 - 20-06-15 The oil needs to be relatively low viscosity-Scottoiler do a Red & a Blue oil depending onambient temperature. When set up correctly the device can deliver one or two drops of oil per minute to keep chain lightly lubricated extending life of chain & sprockets. Not really expensive when you compare the extended life obtained with the cost of a 500ml bottle. Re: Scott oiler oil.... - tony_d123 - 20-06-15 The price of a couple of pints of beer! Stop,bing a tight arse, use the proper stuff. as mentioned it lasts for ages if set up properly so not really a major expense over a couple of years. Re: Scott oiler oil.... - Fazerider - 20-06-15 Well I'm proud to be a tightarse. I've not used overpriced Scot Oil since finishing the bottle that came with the kit. Engine oil is fine, lately I've been using it mixed 50:50 with chainsaw oil which clings to the links better. Re: Scott oiler oil.... - stevierst - 20-06-15 It all depends on how much mileage you do, and what weather you ride in. Red Scottoil is useless in the winter as it doesn't flow due to low temp, and blue Scottoil washes off in the rain. Regular engine oil is the best if your a 365 biker as it flows in all temps, and doesn't wash off as easily. I just use cheap supermarket oil and fil it up every time it gets low. As for making a mess, well you have to degrease your back wheel anyway, so no change there then. Other tan that if your fair weather or recreational rider, blue Scottoil is fine and will double the life of your chain! Re: Scott oiler oil.... - paulchucky - 20-06-15 use cheap 2T injection oil from (tesco/asda/morrisons) etc the comma stuff it does the job and is like 2.50 per litre Re: Scott oiler oil.... - purplebear7 - 20-06-15 I'm not a tight arse ... I'm an OAP illegal immigrant and money is money :\. Used Scottoiler's for many years ... since day one in fact ... on many bikes. I've never had to buy a drive chain. I use old engine oil these days ... just let it cool and settle or a week then skim the top surface off for the Scotty :o) If you are buying a new kit there will be a bottle of oil in the box ... always was anyway. A Wet Chain is a Happy Chain ... Navy Training 8) Stay Safe Polar Bear Mallorca.Re: Scott oiler oil.... - Fazerider - 20-06-15 (20-06-15, 09:43 AM)purplebear7 link Wrote: I'm not a tight arse ... I use old engine oilEven I wouldn't use that carcinogenic waste. :lol Re: Scott oiler oil.... - NorthWestern - 20-06-15 I dunno, I find if I use engine oil through winter it gets much dirtier than with proper stuff. I will use whatever I have really, anything is better than nothing
Re: Scott oiler oil.... - kebab19 - 20-06-15 Scottoil is relatively expensive. I've forced hypoid ep80/90 gearbox oil and ATF through mine in the past, no obvious ill effects. Re: Scott oiler oil.... - stevierst - 20-06-15 I used to recycle my engine oil through the Scottoiler, but its grotty as hell! I still didn't have to change a chain though 8) Re: Scott oiler oil.... - Slaninar - 20-06-15 (20-06-15, 09:09 AM)Fazerider link Wrote: Well I'm proud to be a tightarse. I've not used overpriced Scot Oil since finishing the bottle that came with the kit. Texture of the red (hi-temp - the only one we use in Serbian climate ) Scot Oil is the same as a chainsaw oil called "testerol", sold locally here. It looks, smells and feels the same under one's fingers. Haven't tried it yet in a scottoiler.I'd rather not pay more than I have to if I don't have to. Regardles of the difference. Will try engine oil. I wouldn't try used engine oil - it is dirty, poisonous and bad for chains (all the acids built up during it's use). I've tried it on bicycle chains and it's good for nothing, except painting old wood, or burning in oil heaters. Re: Scott oiler oil.... - mtread - 20-06-15 I seem to remember Scottoil includes some sort of cleaning agent. Done over 20k on my chain with one, and it always looks wet and clean Re: Scott oiler oil.... - john 087 - 20-06-15 i fitted a scotoiler as well, use the scotoiler oil when set up right its a great job and easily cleaned. Re: Scott oiler oil.... - tony_d123 - 20-06-15 (20-06-15, 09:43 AM)purplebear7 link Wrote: I'm not a tight arse ... I use old engine oil It must make a right mess of the wheel, the clean stuff is grotty enough :eek Re: Scott oiler oil.... - Punkstig - 20-06-15 I've found engine oil too thin and runs too much causing excessive oil to spray everywhere - but the different oil delivery tube lengths affect delivery. Gear oil is cheaper than official scottoil and flows well on my set up, I use the really thick stuff in summer Re: Scott oiler oil.... - Slaninar - 22-06-15 (20-06-15, 11:21 PM)Punkstig link Wrote: I've found engine oil too thin and runs too much causing excessive oil to spray everywhere - but the different oil delivery tube lengths affect delivery. SAE90 gear oil is about the same viscousity (thickness) as a 20w60 engine oil. I use either on bicycle chains in the summer, while for winter I use synthetic 5w40, or "thinner". |
