Front brake calipers, FZS600. - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: Front brake calipers, FZS600. (/showthread.php?tid=72938) |
Front brake calipers, FZS600. - eightcans - 18-06-15 Newbie with a front brake caliper question that has probably been asked more than once... :rolleyes Are the original and facelift Fazer front brake calipers the same please. Want to refurb a spare set of calipers so when it comes to replacing the original worn pads I can do a refurbed caliper swap. Thanks if you can help. Guy Re: Front brake calipers, FZS600. - darrsi - 18-06-15 Do you mean Boxeye model compared to Foxeye model, if so they're all the same? Re: Front brake calipers, FZS600. - Val - 18-06-15 (18-06-15, 07:58 PM)eightcans link Wrote: Newbie with a front brake caliper question that has probably been asked more than once... :rolleyes Are the original and facelift Fazer front brake calipers the same please. Want to refurb a spare set of calipers so when it comes to replacing the original worn pads I can do a refurbed caliper swap. They are the same, but there is left and right one: 5dm-2580t-00 and 5dm-2580u-00 Not only fit all years 98-03 FZS 600 models, but also: [size=1em][/size]YZF-R6, FZS 1000, XJR 1300, BT 1100. Re: Front brake calipers, FZS600. - eightcans - 19-06-15 Thanks Its a Foxeye model, not heard of a Boxeye... :o Re: Front brake calipers, FZS600. - BBROWN1664 - 19-06-15 boxeye = square headlights (the original 1998 model) Re: Front brake calipers, FZS600. - riedrider - 19-06-15 Quote:Not only fit all years 98-03 FZS 600 models, but also: YZF-R6, FZS 1000, XJR 1300, BT 1100.And YZF-R1 1998 to 2001 and 2002/2003 but then with golden stars and aluminium pistons, and TDM 900
Re: Front brake calipers, FZS600. - loadeddice - 21-06-15 Err...I've just rebuilt my 600, with refurbed calipers. However, my replacement calipers are identical apart from the banjo bolt location. The new caliper has a 90 degree change in banjo bolt orientation + a balance pipe. Re: Front brake calipers, FZS600. - riedrider - 22-06-15 Quote: However, my replacement calipers are identical apart from the banjo bolt location. The new caliper has a 90 degree change in banjo bolt orientation + a balance pipe.This is the old version from the Tundercat and Thunderace. Re: Front brake calipers, FZS600. - loadeddice - 22-06-15 Aha, I had suspected, (& should have remembered from my 2 T/cats back in '99). Thx riedrider |
