stuck rear wheel drive hub - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: stuck rear wheel drive hub (/showthread.php?tid=72863) |
stuck rear wheel drive hub - Val - 13-06-15 Hello, I am trying to check the dampers on my rearĀ wheel. And cannot remove the rear sprocket coupling. It is stuck. In the parts catalog that is called rear wheel drive hub. Haynes manual calls it rear sprocket coupling. There are 6 drive hub dampers I want to check. Any help is appreciated. Am I missing something? I have removed the rear wheel and the sprocket coupling is supposed to get off. It is stuck, I mean like welded stuck. I have tried gentle hammering. Any ideas? cheers Val Re: stuck rear wheel drive hub - maxzer1500 - 13-06-15 You need a decent sized piece of wood passed through from the other side using a club hammer and go round evenly like opposite then 90 degrees different then opposite etc. If it's that tight when you put it back together it might not close up that last little bit, the action of tightening the spindle will do the rest. Also if it's that tight there is probably not that much wrong with it wear wise. Re: stuck rear wheel drive hub - darrsi - 13-06-15 (13-06-15, 07:14 AM)maxzer1500 link Wrote: You need a decent sized piece of wood passed through from the other side using a club hammer and go round evenly like opposite then 90 degrees different then opposite etc. If it's that tight when you put it back together it might not close up that last little bit, the action of tightening the spindle will do the rest. Also if it's that tight there is probably not that much wrong with it wear wise. +1 to that, i bought a new set but seriously couldn't tell the difference between old and new? Re: stuck rear wheel drive hub - Val - 13-06-15 thank you guys no wear and I will just leave it the way it isĀ
Re: stuck rear wheel drive hub - darrsi - 13-06-15 I can imagine the rubbers possibly being shot if the bike was abused or raced, but when i compared my old to new i just couldn't tell any difference? Re: stuck rear wheel drive hub - His Dudeness - 13-06-15 If the sprocket carrier isn't moving around the rubbers are probably fine. If you really want to get it off try standing on the rim and pulling up on the sprocket |
