Rear Caliper seal... - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: Rear Caliper seal... (/showthread.php?tid=72840) |
Rear Caliper seal... - anutz - 10-06-15 So when i took off my OEM caliper i thought it was toast....so put a 1000 caliper on it... Now that i know a little more....or have done a lot with the front and rear braking i think it will actually be salavagable.... But i have lost a little "O" ring seal i think Anyone know what part this is, i cannot see a caliper expanded to this level in parts catalaogs... The seal goes i think in the recess on the second pic, of course these are the 2 "halves..." of the caliper... ![]()
Re: Rear Caliper seal... - unfazed - 10-06-15 Someone posted this site some time ago and they do the full set of seals for the FZS600 rear caliper. http://www.powerhouseautomotive.co.uk/content/motorcycle-brakes/motorcycle-brake-caliper-services.php Re: Rear Caliper seal... - anutz - 10-06-15 ah never thought of checking them!!! I shall see what they have, would be nice to get it back in working order.... Re: Rear Caliper seal... - anutz - 10-06-15 OK so they DO have the so called 1/2 joint seals....which is good... Re: Rear Caliper seal... - celticdog - 12-06-15 O rings, don't you just love 'em. You compress them axially they expand radially! Have you got a pair of vernier calipers handy? It's a standard engineering part, with a bit of work you should be able to source what your after for a few bob
Re: Rear Caliper seal... - limax2 - 12-06-15 A few years ago someone on this site said the seal for a Suzuki GS500 rear caliper was the same. Pt Number 6910734200. Wemoto show the size as 6.5 x 11.5 x 2.2 Not used it myself so I can't confirm that info. Re: Rear Caliper seal... - anutz - 12-06-15 Thanks for the responses guys, so i will have a look on fleabay, will be sure to find what i need... When i find out will let you know....i have all i need to rebuild apart from these 1/2 seals! Re: Rear Caliper seal... - Pickle - 12-06-15 If you are buying O-Rings on Fleabay be aware of the type of rubber for brake fluid compatibility. Buna - NO Nitrile-NO EPDM - YES AFLAS - YES Re: Rear Caliper seal... - anutz - 12-06-15 thanks pal....will make sure i do my research.. i picked up another rear on ebay for 10£ last night - at that price i could not pass on it - i will open that up and post pics of the seals as well.. once i am done i should have a couple of nice condition rear calipers, my old one and this one... Re: Rear Caliper seal... - paulchucky - 12-06-15 auntz meassure the seals with veneer gauge let me have the size and i`ll send you some foc i`m a plumber/boiler engineer and have 100`s ov the little rubber foccers Re: Rear Caliper seal... - anutz - 12-06-15 (12-06-15, 05:05 PM)paulchucky link Wrote: auntz meassure the seals with veneer gauge thanks, i shall do that, the 2nd caliper will be here next few days so will split it and let you know - thanks a lot!
