Wobbly mirror - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: Wobbly mirror (/showthread.php?tid=72766) |
Wobbly mirror - Jamieg285 - 04-06-15 I should have left well alone! Having asked and been told that the foxeye mirrors do fold in, I duely went and did so. The problem is when I pushed it back it didn't centre where it was and is now as wobbly as a 30 year old transit gear stick. Is there an easy fix for this, or will I have to replace the mirror? Re: Wobbly mirror - Arfa - 04-06-15 The hinge is riveted and once bust is gone. You'll be able to peel back rubber and shove a new bolt through, but it'll probably loosen off in no time. I picked up a cheap mirror off eBay a while back, with a loose ish hinge. Week later it fell off and low and behold the rivet had been replaced with a bolt. Got it refunded, didn't even want it back, reckon seller knew full well it was fooked! |
