Done to death........but - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: Done to death........but (/showthread.php?tid=72730) Pages:
Done to death........but - 7omly - 01-06-15 I haven't been out in the dark yet on my boxeye fsz600 yet and I know the lights are meant to be poor. The lights on my old divvie were nothing special with poor penetration and never too bright even with a night breaker bulb. Excuse my ignorance here but has anyone tried to use to H4's in both lamps by modifying the bulb holders or is this a waste of time. I ride all year round :rolleyes and I'd appreciate the best lighting I can get. The projector set up looks good but at £180 ouch. Any suggestions as to how to improve them for a reasonable price would be appreciated. All the best. Re: Done to death........but - 72 chamb - 01-06-15 I did the headlight mod last week...all the bits from halfords and cost me about a tenner..it took 30 mins to do and is alot better.. Re: Done to death........but - unfazed - 01-06-15 When I had the 2000 model Boxeye I modified the left holder to take a H4 bulb. From what I can remember, it was a lot better than the original, but it was a a tedious job doing it, but was worth it.
Re: Done to death........but - 7omly - 02-06-15 Unfazed, greater moniker, how many club members wish they'd got to that one first? When you say tedious I thought it would be just a case of finding a H4 fitment from the local car breakers and gluing it in place. The electrics isn't a problem as I'm a bit of a dab hand and love a challenge. I'll be wiring it through two sets of 5 terminal switching relays to take any extra load and I'll be making a custom wiring harness. I've done this before for cars and bikes and feel comfortable. The only bit that might 'faze' me is the actual bulb holder itself. I figure I can make the harness for around £20 all in because I already have the wiring. If I do it and I have the time I will try to make a guide for others including a wiring diagram. All the best Re: Done to death........but - Paulfzs - 02-06-15 save yourself a fortune!! http://foc-u.co.uk/index.php/topic,15666.0.html Re: Done to death........but - crickleymal - 02-06-15 I modified my Divvy by fitting a couple of relays to bypass the switches on the handlebars. It made a huge difference to the brightness and didn't seem to diminish the life of the bulbs significantly. Re: Done to death........but - limax2 - 02-06-15 The link below might be useful to you. Half way down the first page is a wiring diagram I did some time ago. It's for fitting the Foxeye headlamp with two dips and two main beams to a boxeye, but that sounds just the same as what you are trying to do. i.e two H4 bulbs. The Foxeye wiring diagram does it in a different way and uses different relays for the same result, but would mean more complicated changes to the main wiring harness on a boxeye model.[color=rgb(74, 74, 74)]http://foc-u.co.uk/index.php/topic,5252.0.html[/color] Re: Done to death........but - limax2 - 02-06-15 this might be useful to you. There is a wiring diagram part way down the first page. http://foc-u.co.uk/index.php/topic,5252.msg45694.html#msg45694 Re: Done to death........but - unfazed - 02-06-15 (02-06-15, 01:08 AM)7omly link Wrote: Unfazed, greater moniker, how many club members wish they'd got to that one first? I modified the hole itself to take the H4 bulb, which was why it was so tedious as I had only one shot at it to get it right. I would suggest you use the relay setup as in the foxeye. One make relay and one change over relay. If you get the specific relays the foxeye uses (or better still the headlight wiring loom) it would be better as thay have diode protection built in, just make sure you wire them the right way round :lol Re: Done to death........but - sinto607276 - 02-06-15 (02-06-15, 02:51 AM)Paulfzs link Wrote: save yourself a fortune!!You still trying to flog your idea? :lol Re: Done to death........but - sinto607276 - 02-06-15 (02-06-15, 08:31 PM)unfazed link Wrote: I modified the hole itself to take the H4 bulb, which was why it was so tedious as I had only one shot at it to get it right.Can you remember how you done this? Dremel and patience I'm guessing, but wondering more about sizing it up and how it clipped in? I'm ok with the wiring of it etc
Re: Done to death........but - unfazed - 02-06-15 That was back in 2002 before I even knew what a Dremel was or heard of one :lol I used 3 small files, flat, round, and triangular plus a junior hacksaw blade and as far as I can remember used the original clip for the H2 bulb to hold it in place. Never said it was easy, but I had plenty of time as I was out of work due to an altercation with the front wheel of a truck :lol where bike escaped, but I didn't :eek Sizing was trial and error with a blown H4 bulb. Remove the rattly bulb cap put in the H4, mark it with marker, remove bulb cut and file holder, bulb back in mark some more and do the same again. Re: Done to death........but - fazersharp - 02-06-15 Yep the standard FOC u.co.uk for me which puts on both OEM bulbs at dipped BUT the right one ( is it the right, been so long I cant remember ) although normal dipped filament lit it looks brighter on account that it is pointing more to the right as opposed to pointing at the kerb, I also fitted an in-line fuse that I can take out for the MOT so as to revert the beam back to the correct alignment------- although all the tester dose is check I have a normal and full beam -- dont care where it points. Re: Done to death........but - sinto607276 - 03-06-15 (02-06-15, 11:28 PM)unfazed link Wrote: That was back in 2002 before I even knew what a Dremel was or heard of one :lol Cheers for the info unfazed, might look into giving it a try someday when I've got time, admitted, I don't want the spare time the same way you found it :eek Re: Done to death........but - Paulfzs - 03-06-15 (02-06-15, 10:28 PM)sinto link Wrote: [quote author=Paulfzs link=topic=17161.msg197903#msg197903 date=1433209877]You still trying to flog your idea? :lol [/quote] hell yes! they work so well itd be rude not to ! Re: Done to death........but - sinto607276 - 03-06-15 (02-06-15, 11:44 PM)fazersharp link Wrote: Yep the standard FOC u.co.uk for me which puts on both OEM bulbs at dipped BUT the right one ( is it the right, been so long I cant remember ) although normal dipped filament lit it looks brighter on account that it is pointing more to the right as opposed to pointing at the kerb, I also fitted an in-line fuse that I can take out for the MOT so as to revert the beam back to the correct alignment------- although all the tester dose is check I have a normal and full beam -- dont care where it points. Yeah I've got that already, (btw, it's the right side if your sitting on the bike) even took out the shield and used inside of garage door to adjust slightly and not had anyone tell me I'm blinding them, (which makes me think, have they seen me?? Foc, I might need to raise them up a bit :lol Re: Done to death........but - sinto607276 - 03-06-15 (03-06-15, 12:30 AM)Paulfzs link Wrote: [quote author=sinto link=topic=17161.msg198024#msg198024 date=1433280503]You still trying to flog your idea? :lol [/quote] hell yes! they work so well itd be rude not to ! [/quote] :rollin :rollin Re: Done to death........but - 7omly - 03-06-15 I was thinking of a trip to the local scrappy and just get a H4 holder off a headlamp and superglue it to the back of the reflector. Obviously after removing the H1 bulb holder. Re: Done to death........but - 7omly - 25-06-15 I've bitten the bullet and purchased two sets (H1 and H4) off fleabay. I bought car sets so I intend to try the H1/H4 original set up and if happy with it leave it at that. If this is sufficient it will leave me with a spare bulb and ballast for each side. If not I'll fit two H4's. I'll let you know how I get on. Re: Done to death........but - sinto607276 - 25-06-15 (25-06-15, 08:14 PM)7omly link Wrote: I've bitten the bullet and purchased two sets (H1 and H4) off fleabay. I bought car sets so I intend to try the H1/H4 original set up and if happy with it leave it at that. If this is sufficient it will leave me with a spare bulb and ballast for each side. If not I'll fit two H4's. I'll let you know how I get on. Don't want to piss on your parade, but you'll find it hard to fit those car ones unless you got the slim ballasts with them, the other thing you've got to make sure is that they are waterproof :eek |
