Front wheel movement... - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: Front wheel movement... (/showthread.php?tid=72715) |
Front wheel movement... - mars696 - 31-05-15 Hi there foccers! My front wheel has develop a strange gap-movement the last weeks... I though it was the steering bearings,which i replaced yestreday,but thats when i realize its the wheel which moving... The wheel bearings are also changed a year ago....its possible to need new again? Or maybe something with my spindle or my installation? Thanks, Aris. Re: Front wheel movement... - anutz - 31-05-15 Have you had the axel etc out and re-torqued up correctly, speedo cup and rotor sitting flush etc.... Re: Front wheel movement... - darrsi - 31-05-15 What about pad movement in the caliper, some pads do fit better than others. Re: Front wheel movement... - His Dudeness - 02-06-15 Check the bearings definitely. Don't ride it until you fix it. That could cause an accident Re: Front wheel movement... - mars696 - 02-06-15 I will change the bearings again. I dont want to risk it. Anybody knows the numbers for the bearings? I dont remember were i have read them, somewhere... Thanks for the responces guys! Edit: i found them!thanks! |
