USB/Charger Port - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: USB/Charger Port (/showthread.php?tid=72681) Pages:
USB/Charger Port - dilboy - 28-05-15 I would just like to say ,I've installed a car charger/usb port under the seat and it works fine, plus I've not broken or set the bike on fire in the process, hurrah for me
Re: USB/Charger Port - anutz - 28-05-15 any pics....would like to see the wiring if i can - nice - i might have a bash! :lol Re: USB/Charger Port - HarryHornby - 28-05-15 :agree Re: USB/Charger Port - dilboy - 28-05-15 (28-05-15, 04:18 PM)anutz link Wrote:any pics....would like to see the wiring if i can - nice - i might have a bash! its really easy, just positive and negative straight from the battery, I put a fuse in, but didn't need it so took it out, bought it from evil bay
Re: USB/Charger Port - Ebme Geek - 28-05-15 Fuses are always good, as close to the battery as posible, if they are correctly rated they protect the wires after them An abraded or crushed wire under the seat can become a fire starter :'(
Re: USB/Charger Port - dilboy - 28-05-15 I put a 15a fuse in and there was no power so that's why I discarded it, but the words fire and bike bother me :eek Re: USB/Charger Port - anutz - 28-05-15 OK so you have attached the new circuit to the +/- of the battery directly....??? So you now have an un-fused circuit which is never a good idea, the fuse's job is to make sure IT melts before the wires carry current at such a level they can heat up and cause issues i.e. fire and other lovely things.... I would not run it unless it was fused - you need to know what the wires are rated to carry, doubt it is much being a USB charger, they most likely will not be very large gauge... do you have a link to the device you installed???? Regardless don't connect it all up until you know why the 15A fuse did not work, USB devices usally charge at 5V and normally we are talking Milliamps to 1/1.5A i.e. 1000-1500mA current draw A 15A fuse for this application may well be incorrect, the wires, depending on their gauge will have a specific amperage they can carry and a specific fuse will be needed to protect them from over current situations... Regardless be careful as i am no electrician but this stuff is important Anyone around here offer any advice? Re: USB/Charger Port - anutz - 28-05-15 Depending on the device it MIGHT already have its own fuse built in? SEE FURTHER POSTS FOR IMPORTANT POINT ON FUSING AT THE SOURCE AS WELL Not that i would do this dismantel and hack - but some chargers will contain internal fuses......but that does not protect the wiring leading to it, hence the above comment http://geekgreek.com/2010/03/add-a-usb-port-to-your-motorcycle/ Re: USB/Charger Port - anutz - 28-05-15 If you have somethnig like this it might be ready to connect up i.e. has the inline fuse holder etc...and lugs etc http://www.windingroads.co.uk/shop/product.php/984/motorcycle-usb-12v-charger/365496122dc8f833d60d82681302a201 Re: USB/Charger Port - anutz - 28-05-15 also may be obvious but be careful you do not drain the battery too low if you leave something plugged in and the engine not on - if the voltage on a battery gets too low they can be history i left my parking lights on once by accident - day after i got the bike, i never managed to get the battery above 3.5V ever again so my oxford charger would not do a thing - got a new battery in the end.. Some USB charging systems can shut off when the battery supply voltgage it low Re: USB/Charger Port - slappy - 28-05-15 261662925268, ebay link if it works! Just put one of these on, thats what I did, I just took a feed from a relay I had already fitted that is only live when ignition is on. I got the wiring diagram from this site so if you do a search you should find it, but to tell you the truth it was very straight forward and I honestly have no idea about electrics. No problems so far but I avoid riding in rain as much as possible, I have had my phone and an old tomtom satnav running off it . Re: USB/Charger Port - Ebme Geek - 28-05-15 (28-05-15, 09:39 PM)anutz link Wrote:"A 15A fuse for this application may well be incorrect," - Absolutely !! - VERY likely incorrect & probably dangerous !!! The fuse will only protect what is after it, hence why it should be kept as close as possible to the battery. :book The example anutz gives you can just about see a fuse holder behind the main box with a red wire either side of it, about 5" from the ring terminal for the battery. Rating wise I would only expect a 1amp or at the most 2amp fuse, but it depends on the device, how many outputs, etc Re: USB/Charger Port - anutz - 28-05-15 good points ebme geek :b So after research Ebme Geek you seem spot on...fuse as close to the source, else you do have areas for potential shorts and unprotected wire..... "It is important to note that the section of cable coming from the battery +ve terminal to the first fuse (or battery distribution box) is effectively an unprotected part of the circuit. If there is a short anywhere along this length then it is very likely to catch fire as the first fuse will not experience the excess current. For this reason the length of cable from the battery +ve to the first fuse should be as short as possible so that damage is minimised in the event of an electrical fire.." Re: USB/Charger Port - anutz - 28-05-15 interesting link on fusing... http://www.12voltplanet.co.uk/fuses-guide-uses.html Re: USB/Charger Port - Ebme Geek - 28-05-15 (28-05-15, 10:33 PM)anutz link Wrote:why RED? :o I was only trying to emphasise your coment as correct, I have modified my post, hope it now reads as I meant it Oh - and yes, the link slappy put up has an in line fuse in the 5th picture as well, looks like a connector but it's actually open and you can see a glass fuse sticking out of one half of it. Re: USB/Charger Port - fazersharp - 28-05-15 (28-05-15, 09:39 PM)anutz link Wrote:Regardless be careful as i am no electrician but this stuff is important So you say --- but I know who to ask if I have an electrical problem on my bike now ! Re: USB/Charger Port - dilboy - 29-05-15 this is the item I bought http://www.ebay.co.uk/itm/141404165733?_trksid=p2060353.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT Black 12V Universal Cigarette Lighter Re: USB/Charger Port - dilboy - 29-05-15 First of all thanks for all the advice and fear of fire :eek I have now refitted the fuse nearer the battery and fuck a duck it works fine ![]() Now will it DE charge my battery if its stood for a while, should I attach some kind of on/off switch ? cheers Novice Dilboy :evil Re: USB/Charger Port - anutz - 29-05-15 lol - scared ths sh*t outta me - hence the "Fire!!!" Thread... http://foc-u.co.uk/index.php/topic,17125.0.html But these are good things to have threads on m8 - we all learn - Ebme Geek corrected me on a point as well so its beneficial! Re: USB/Charger Port - anutz - 29-05-15 OK so what rating fuse did you use - the 15A one - need to check what those wires are rated for to be sure its the correct fuse.......do they have a stamp on the side that lists there AWG/Rating? |
