Re: Carb Balance... - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: Re: Carb Balance... (/showthread.php?tid=72673) |
Re: Carb Balance... - RonnyBlack - 27-05-15 Anyone in Yorkshire (or surrounding areas) able to balance carbs and remove a stubborn spark plug on my Fazer 600 for a crate of beer ??? Am willing to travel as long as you aren't a million miles away from Sheffield...Cheers.Aaron.
Re: Carb Balance... - His Dudeness - 27-05-15 Getting seized sparkplugs out isn't a job for the faint hearted. Make sure whoever does it for you knows what they're at! Re: Carb Balance... - RonnyBlack - 27-05-15 Agreed... Just a carb balance would be great... Cheers. Re: Carb Balance... - Paul - 27-05-15 I've got a set of vac gauges and a garage, but I live in Bolton. Bit of a flog from Sheffield though. Re: The spark plug. Is it on the No.4 (right hand road side cylinder)? Re: Carb Balance... - RonnyBlack - 27-05-15 Hey, thanks Paul. Am frequently in Manchester and have relatives in Colne, Lancashire. Plus any excuse to go for a ride on a nice day... right ??? Unfortunately, no. It's No. 3. I soaked it overnight and then used a socket with as much force as I dare... Wouldn't budge... Other three replaced fine... Regards, Aaron. Re: Carb Balance... - Paul - 27-05-15 Hmm different cylinder to my problemo. I had (and likely still have) a problem with the No.4 spark plug thread. With the exception of the first service from new I've serviced my bike ever since. At around 50,000 miles, which was in 2009 I serviced it and changed the plugs. When I took the No.4 cylinder plug out, a copper washer came with it. The copper washer must have been located under the plug washer. Now I'd done ever service apart from the first one, and I hadn't put it there, and I suspect they didn't change the plugs on the first service because it had only done either 1000km or a 1000 miles. And if they did change the plugs why stick an extra copper washer under one of them? In any event having taken the old plug out, I tried to screw the new one in. No chance, none whatsoever. I ended up re-tapping the plug hole with a old spark plug with grooves filed in the threads and all manner of aluminium shit came out as I did so. Ultimately I managed to get a new plug in (an iridium one), and I decided not to change the plugs again. Oddly enough, or not as the case maybe, the bike still runs o.k. and it's now six years and 30,000 miles later (it's now clocked 80,000 miles) and everything else is worn out anyway... so I guess it doesn't matter that much anymore. As regards vac gauging your carbs, I've done it before for other Foccers, so why not you. I'm still working (old bugger hanging on and trying to get to state pension age), so you'll have to give me a ring to see if I'm available. The works no. is 01204 845382 and my mobile is 07813 439196. Re: Carb Balance... - RonnyBlack - 27-05-15 Hey Paul. 'If it ain't broke... don't fix it' I believe the motto is... Tremendous... will give you a ring in due course... I take it you like 'Special Brew' ??? :lol Best regards, Aaron. Re: Carb Balance... - Paul - 27-05-15 Thanks for beer offer, actually I'm a Guinness man, recent convert.In any event I ask for nothing.... you get a free brew, and if you like, a miniature bottle of my whiskey, that's my other hobby. Strictly for medicinal purposes of course. Ideally you need only a small amount of fuel in the tank (say a gallon), because the tank has to come off to balance the carbs. |
