Overfilled oil on fazer 1000? - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: Fazer 1000/FZ1 corner (https://foc-u.co.uk/mybb/forumdisplay.php?fid=75) +--- Thread: Overfilled oil on fazer 1000? (/showthread.php?tid=72636) |
Overfilled oil on fazer 1000? - Krezi - 23-05-15 Hi Guys,[/size]Looking for some help here!I did a bit of servicing to my Fazer 1000 today and put in new spark plugs, changed air filter and oil and oil filter.Changing oil I tried to measure accurately amount of oil needed but now presume I could've overfilled it. When I started the engine the oil started coming out from a hole on top of the engine just between spark plugs where a kind of hose is located. This hose does not close this hole completely but there is a small gap.I can drain a bit of oil but what about this oil coming from top of the engine? Will it come down or how to get rid of it?Thanks for the help!Paul Re: Overfilled oil on fazer 1000? - mickvp - 23-05-15 translation: Quote: [font=verdana]Hi Guys, where is the oil in the sight glass window on the side of the engine? is it full all the way to the top or not? Re: Overfilled oil on fazer 1000? - Falcon 269 - 24-05-15 Unless you're a complete numpty, hard to see how you could have accurately measured but still over-filled the oil. Is it possible you disturbed this hose you've mentioned with the spark plug wrench? It doesn't make sense for a hose not to completely close a hole, as you described it. Maybe a photo would help us understand better? Re: Overfilled oil on fazer 1000? - Krezi - 24-05-15 (24-05-15, 06:34 AM)Falcon 269 link Wrote: Unless you're a complete numpty, hard to see how you could have accurately measured but still over-filled the oil. Exactly I was very meticulous with the amount I put in so I think I did it right- just assumed I overfilled since the oil was coming out.. All looks ok quantity wise (see first pic below)... The second picture is the hole where the oil is coming from I referred to before. There is this piping coming from the hole and there is a gap around the hose but that's ok I think. I sticked my finger inside this hole and oil mixed with water sits inside. It's not as dense as oil alone, maybe it's the water from undone clip coming inside and getting this kind of oil water mixture?? The hose is securely fastened there is no movement whatsoever. I had some issues removing spark plugs which is close by to the hose but don't think I messed up there since the hose is very secure. I forgot to tighten the little clip where the hoses are coming together overlapping each other. Maybe that's it? If this hose carries oil which I don't think it does the undone clip could have cause the oil there. Also the first thing I replaced was air filter. When removing fuel tank is it possible that if I bent the fuel hoses and others coming from the tank in this area this could cause the leak?? I doubt it as those are two separate areas. THanks a mill! ![]() See the hole I referred to and the metal clip I forgot to tighten. When I put my fingers inside I can feel oil/water sitting there Could it be it??
Re: Overfilled oil on fazer 1000? - unfazed - 24-05-15 The oil level if anything is to low and the bike does not appear to be on level ground. On the right side of the sight glass there are two raised dots the top one is the max oil level and the bottom one is the low oil level. Bike must be on the centre stand and on level ground to check the oil and fill it to the top dot. The hose you refer to is a coolant hose and the large hole is to facilitate bolting the pipe the hose is on to the head. You may have knocked the pipe out of alignment when removing the plugs and it is now leaking coolant. Re: Overfilled oil on fazer 1000? - esetest - 24-05-15 if your bike is on the centre stand , it's too low on the sight glass . If it's on the side stand , it's too high . Re: Overfilled oil on fazer 1000? - Krezi - 24-05-15 thanks guys! Problem solved! It was the bloody metal clip... No leak now but coolant is on low side so will add a bit as well as oil top up as it was on centre stand Paul |
