Throttle cable rubber cover on handle bars - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: Throttle cable rubber cover on handle bars (/showthread.php?tid=72608) |
Throttle cable rubber cover on handle bars - Arfa - 20-05-15 On the throttle cables just before they go into the throttle grip on the bars, there's a little rubber cover for the join between the metal housing and the two cables the come off from it. I've gone and shredded this on my last off. Picked up a whole throttle cable assembly off ebay cheap, but I can't see how I can swap over this rubber cover on it's own, there's just too much plastic cable guides and stuff in the way to slide it off. Am I being daft, or do I really need to swap the entire length of the throttle cables to change this rubber bit? Re: Throttle cable rubber cover on handle bars - Punkstig - 20-05-15 Afaik the rubber part you are talking about comes with a new cable, genuine are just over £40, pattern is £20 both from wemoto! http://www.wemoto.com/bikes/yamaha/fzs_600_fazer/98-99/picture/throttle_cables_set_a+b_push_and_pull_-_slinky_glide/ Re: Throttle cable rubber cover on handle bars - noggythenog - 20-05-15 Yep...comes as a complete item im afraid......i only know coz i did the one on my thou recently......i scuffed my 600 one but that didnt matter and i just taped around it as a bodge. Re: Throttle cable rubber cover on handle bars - Arfa - 21-05-15 Fair enough, just as I expected. Swap whole cable it is then. |
