bridgestone bt023 road noise... - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: bridgestone bt023 road noise... (/showthread.php?tid=72547) |
bridgestone bt023 road noise... - Mike01 - 16-05-15 Good morning all! So i have the above on my 600, only had the bike and my licence a short while.. Anyhow the noise that i can only presume is coming from the front tyre is very loud, i have checked everything i can and am certain its the tyre (grumbly road noise not squeeks etc). It changes depending on road condition, obviously bad road - louder I get a low tone rubbing noise when free wheeling the bike out of my garage, was never worried about it as thought its just the pads sat against disc(?)... Wheel has no wobble and spins as it should when raised.. I did a search and the BT021 was well known for this problem but cant find anything about the 23 being the same. So anyone used these, had issues or think it could be something else. Cheers. Re: bridgestone bt023 road noise... - Frosties - 16-05-15 As you've said probably the front tyre starting to square off. Possibly gone hard due to its age so check the tyre date. Also check to see if you've lost any wheel balance weights. Good luck fella. Re: bridgestone bt023 road noise... - Mike01 - 16-05-15 (16-05-15, 10:08 AM)Frosties link Wrote: As you've said probably the front tyre starting to square off. Possibly gone hard due to its age so check the tyre date.Thanks mate, never thought of checking tyre age as they look so new/fresh if you know what i mean They dont look to be squared off but could be old as bike only done just over 9k miles.Will check weights too but dont remember seeing any, i take it they would be the same type used on car tyes, on the rim? Cheers. Re: bridgestone bt023 road noise... - darrsi - 16-05-15 My front is a newish BT023, i have very sensitive hearing but not noticed any noise at all to be honest. Re: bridgestone bt023 road noise... - Mike01 - 16-05-15 (16-05-15, 01:56 PM)darrsi link Wrote: My front is a newish BT023, i have very sensitive hearing but not noticed any noise at all to be honest. Just checked and mine are only 16 months old, done around 1500 miles. I did 1k of those in 2 months!! Oh well maybe have a chat with the local bike garage see what they think. Re: bridgestone bt023 road noise... - darrsi - 16-05-15 Not had a new chain recently, or moved the rear wheel at all? Re: bridgestone bt023 road noise... - Mike01 - 16-05-15 (16-05-15, 02:57 PM)darrsi link Wrote: Not had a new chain recently, or moved the rear wheel at all? Nope, fairly convinced it's coming from the front though. Could be wrong
Re: bridgestone bt023 road noise... - sinto607276 - 16-05-15 (16-05-15, 02:50 PM)Mike01 link Wrote: Just checked and mine are only 16 months old, done around 1500 miles. I did 1k of those in 2 months!! Check the tyre pressures properly, that can make a difference too. Oh, also check that they are on the right way, I was out with someone years ago and he had his tyres on for months and done quite alot of mileage, but his tyres were both on the wrong way :thumbdown He was a lucky bunny nothing happened :thumbup Re: bridgestone bt023 road noise... - darrsi - 16-05-15 Presumably it still makes a noise when the clutch is pulled in? Re: bridgestone bt023 road noise... - Mike01 - 16-05-15 (16-05-15, 03:01 PM)sinto link Wrote: [quote author=Mike01 link=topic=16978.msg195827#msg195827 date=1431784248] Check the tyre pressures properly, that can make a difference too. Oh, also check that they are on the right way, I was out with someone years ago and he had his tyres on for months and done quite alot of mileage, but his tyres were both on the wrong way :thumbdown He was a lucky bunny nothing happened :thumbup [/quote] I will check pressures again, last check was 34f 39r I think. Will check rotation marks too ![]() Yes darrsi clutch in makes no difference. Cheers guys. Re: bridgestone bt023 road noise... - darrsi - 16-05-15 Sure it's not chain noise, rubbing on the plastic chain guide? Re: bridgestone bt023 road noise... - Mike01 - 16-05-15 (16-05-15, 03:37 PM)darrsi link Wrote: Sure it's not chain noise, rubbing on the plastic chain guide? Nope, checking now. Tyres right way round, both wheels free moving with no wobbles just the front pads kissing the disc slightly. Re: bridgestone bt023 road noise... - Chris - 16-05-15 front wheel bearings? mudguard rubbing somewhere? Chris Re: bridgestone bt023 road noise... - Mike01 - 16-05-15 Bearings feel ok, pushed pulled everything and nothing lose or rubbing. Cold tyre pressure 31f 39r.... front too low, could that cause it... Re: bridgestone bt023 road noise... - darrsi - 16-05-15 (16-05-15, 03:53 PM)Mike01 link Wrote: Bearings feel ok, pushed pulled everything and nothing lose or rubbing. Yes, that is low Re: bridgestone bt023 road noise... - darrsi - 16-05-15 I'm running 36/40 Re: bridgestone bt023 road noise... - Mike01 - 16-05-15 (16-05-15, 03:57 PM)darrsi link Wrote: I'm running 36/40 Will sort them now, sun's out so will go play for a bit and see 8) Re: bridgestone bt023 road noise... - sinto607276 - 16-05-15 (16-05-15, 03:56 PM)darrsi link Wrote: [quote author=Mike01 link=topic=16978.msg195843#msg195843 date=1431788021] Reply #9 by Mike01 on 16 May, 2015 15:24 Post actions I will check pressures again, last check was 34f 39r I think. [/quote] Original tyre pressures quoted were 34f 39r Think someone has let air out them inbetween posts :lol Re: bridgestone bt023 road noise... - Mike01 - 16-05-15 (16-05-15, 04:25 PM)sinto link Wrote: [quote author=darrsi link=topic=16978.msg195844#msg195844 date=1431788207] Reply #9 by Mike01 on 16 May, 2015 15:24 Post actions I will check pressures again, last check was 34f 39r I think. [/quote] Original tyre pressures quoted were 34f 39r Think someone has let air out them inbetween posts :lol [/quote] Yep :lol Well has that sorted it.... lol I think so but I now have riding listening for noise syndrome :rollin Re: bridgestone bt023 road noise... - sinto607276 - 16-05-15 (16-05-15, 04:38 PM)Mike01 link Wrote: Well has that sorted it.... lol I think so Great if that's it simple but effective :lol(16-05-15, 04:38 PM)Mike01 link Wrote: but I now have riding listening for noise syndrome :rollinWe all have that! It's called simply 'riding an old bike' :rolleyes |
