vibration - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: vibration (/showthread.php?tid=72512) |
vibration - sinto607276 - 12-05-15 Getting vibration through handlebars that I've not had before ![]() Only thing I've done recently, or when I've noticed the vibration, is changing the rear footpegs from a 2000 model onto my 1998. Admittedly it moves the exhaust back a wee bit but don't think that's the problem but I could be wrong, so any of you guys got any ideas as to what's happened? 98 bike, original exhaust, standard air filter, 24000 miles. Do feel it coming on even after a short run, 10 miles, to work and I do like to use the rev range and done so before changing pegs. Cheers. vibration - mickvp - 12-05-15 When was the last time you balanced the carbs? Worthwhile doing that to see if it smooths things out. I can loan you my carbtune if you don't have one as I know your local to me ![]() Is it more vibey over the whole rev range or just at a spot/spots? Re: vibration - sinto607276 - 12-05-15 (12-05-15, 10:17 PM)mickvp link Wrote: When was the last time you balanced the carbs? Worthwhile doing that to see if it smooths things out. I can loan you my carbtune if you don't have one as I know your local to meI've never balanced the carbs mick, and tbh I really would need to read up on it to see how to do it. I'm just wondering why it would start doing this all of a sudden or is it just coincidence it happened after I replaced the rear pegs? I would say it's more noticable about the 5k and upwards Re: vibration - anutz - 12-05-15 as we have said before Sinto....aliens.... Re: vibration - sinto607276 - 12-05-15 (12-05-15, 10:25 PM)anutz link Wrote: as we have said before Sinto....aliens....They're going to get foccin lazered if i find them :rollin Re: vibration - mickvp - 12-05-15 I can give you a hand with it mate. It's a piece of piss, I did my old fazer 600 a couple of times (I think there is a guide on here for it somewhere actually, maybe in the Hanes manual in the downloads section) Changing the pegs may have highlighted it, but it only takes for them to be out a bit to cause some vibration on the 600s, especially in the 5-6k rpm range. Re: vibration - anutz - 12-05-15 it was the first job i did ..... http://foc-u.co.uk/index.php/topic,15985.msg183713.html#msg183713v Re: vibration - mickvp - 12-05-15 Here's the guide http://foc-u.co.uk/index.php?topic=91 Re: vibration - anutz - 12-05-15 looking at mine in my first post i need to balance the 2 sides now! Another job to do! Re: vibration - sinto607276 - 12-05-15 Cheers Mick and anutz, I know what I'll be reading on my lunch break tomorrow then
Re: vibration - mickvp - 12-05-15 Just give me a shout if you want a loan of my gauges/a hand mate. No point spending £50 on one when I've got one here Re: vibration - sinto607276 - 12-05-15 (12-05-15, 11:01 PM)mickvp link Wrote: Just give me a shout if you want a loan of my gauges/a hand mate. No point spending £50 on one when I've got one here Yep Mick, taken a note of your offer and will prob take you up on it (beer tokens at the ready) once I've read the details of what's involved to get my head round it first, it's not at the point of I can't ride the bike, but I want to nip it in the bud before it gets worse. The other point to take note of is...I've only had the bike a couple of months, not sure if carbs were balanced before, but I know the two previous owners, so will ask them. Re: vibration - sinto607276 - 12-05-15 Saw this in anutz thread.... Reply #3 by unfazed on 15 Feb, 2015 22:09 "Compared to the SV650 the Fazer 600 would generally not have enough torque to trundle around at idle without slipping the clutch. As said in previous post carb balance and TPS setting will help and set the idle speed to 1200rpm" My idle is just above 1000, could adjusting this make the difference? Re: vibration - darrsi - 13-05-15 (12-05-15, 11:14 PM)sinto link Wrote: Saw this in anutz thread.... You definitely want around the 1200rpm mark, the bike engine will hunt around otherwise, and be a bit of a pain warming up, especially in cold weather if it's lower than that. Make sure the bike is at operating temperature before balancing, take it for a 10 minute spin up the road. If the carbs haven't been balanced recently then you will notice a nice improvement, especially when slow riding in traffic for instance. It will also very slightly alter the tone of the engine as well, as in a little bit quieter, just because the fuel distribution is functioning in a more organised manner. Re: vibration - sinto607276 - 13-05-15 Cheers darrsi, I didn't use it for work today but tonight I went out and started it up, let it warm up and let it idle, noting it wasn't at 1200 revs, think it was more like 900, so I duly changed it and now it's running at near enough the 1200, so my question really is, do you think that alone would sort out the vibration or will I, or should I still, do a carb balance? Re: vibration - Doggy - 13-05-15 Hi Just done the same mod today, will let you know over the weekend if I experience the same issue. Cheers Doggy Re: vibration - sinto607276 - 13-05-15 easy change wasn't it? Yes please, let me know how it affects yours, if any. Original exhaust etc? Personally I don't think it will but would be curious to know, cheers Doggy. Re: vibration - Paulfzs - 14-05-15 i fitted 03 hangers to my 98 didnt give me any vibrations or problems, maybe youve lost a wheel weight Re: vibration - HarryHornby - 14-05-15 Hi Sinto, I'm far from a mechanic but I managed to balance my carbs using the guide from here. It's not too bad to do, one tip, when you head is in the engine trying turning the adjusting nuts try not to shit yourself when the fan kicks in..... :lol And as for a missing wheel weight, good call for my bike, I've had a vibration on the bars that's not the usual 6k buzz (I get that too) it's more like the bars are moving left and right very quickly I wonder if it's a wheel weight
Re: vibration - Jules-C - 14-05-15 Also check tyre pressures, wheel bearings, head bearings and swinging arm bearings |
