R1 / gen1 wheels - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: Fazer 1000/FZ1 corner (https://foc-u.co.uk/mybb/forumdisplay.php?fid=75) +--- Thread: R1 / gen1 wheels (/showthread.php?tid=72437) |
R1 / gen1 wheels - stevierst - 06-05-15 There must be a guru on here that possesses the knowledge! Are any of the R1 wheels compatible with the gen 1 wheels? I've got sports tyres on the Fazer, and s/t tyres on the R1 (2001 fjj model) and wondered if the wheels could be swapped to make better use of my rubber
Re: R1 / gen1 wheels - noggythenog - 06-05-15 Pointless unless they are maxxis Re: R1 / gen1 wheels - stevierst - 06-05-15 You know me better than that Noggy ![]() Re: R1 / gen1 wheels - shrekster - 06-05-15 I believe the fronts are identical as is the R6, the rear on the R1 is a bit wider to accommodate the 190 section tyre. It can be made to fit the Fazer with different spacers, not sure if it needs any other work. The R6 rear wheel might fit as its for a 180 section tyre as well, you'd need to check spacers etc though. Jim. Re: R1 / gen1 wheels - stevierst - 06-05-15 Cheers Jim, much appreciated. Looks like ill leave the wheels where they are. Re: R1 / gen1 wheels - sadlonelygit - 07-05-15 as has been said the fronts are a straight swap but fazer has a different size rear disc for starters. like anything it can be done with enough work. |
