Hand tools: alternative replacement/s for an angle grinder. - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: General (https://foc-u.co.uk/mybb/forumdisplay.php?fid=65) +--- Forum: General (https://foc-u.co.uk/mybb/forumdisplay.php?fid=69) +--- Thread: Hand tools: alternative replacement/s for an angle grinder. (/showthread.php?tid=72415) |
Hand tools: alternative replacement/s for an angle grinder. - b1k3rdude - 04-05-15 As I don't have a garage I am limited to battery powered power tools, I started looking for an angle grinder but at £50-60 for one its a tad too much for something thats gonna get used 1x/2x a year for grinding of the 3mm+ wide rivets on a 530 drive chain. Then a remembered that I've been meaning to replace my mains powered dremel clone, which I used a lot over the last few years with a cordless one. Would a battery poqwered dremel with the right grinding tip do the job? I would use it for this job and flatting off the head of snapped bolts for drilling etc. ta. Re: Hand tools: alternative replacement/s for an angle grinder. - NorthWestern - 04-05-15 I borrowed a lithium battery dremmel a couple of years or so ago. Very nice bit of kit, expensive at the time iirc. Might be more cost effective now or available second hand Re: Hand tools: alternative replacement/s for an angle grinder. - fazersharp - 04-05-15 You can pick up a cheep angle grinder for £20, a few years ago I had to replace a more expensive one half way through a job, and needed it NOW so I just got the cheapest one i could find and about 5 years later its still going, but like you I dont use it that often. If you see one at aldi then get that as it will come with 3 years garntee Re: Hand tools: alternative replacement/s for an angle grinder. - b1k3rdude - 04-05-15 (04-05-15, 06:31 PM)NorthWestern link Wrote: Might be more cost effective now or available second handYeah watching one now. (04-05-15, 09:21 PM)fazersharp link Wrote: You can pick up a cheep angle grinder for £20, If you see one at aldi then get that as it will come with 3 years garnteeIm guessing thats a mains powered unit, NOT battery..? if so no use to me. Re: Hand tools: alternative replacement/s for an angle grinder. - fazersharp - 05-05-15 Quote:m guessing thats a mains powered unit, NOT battery..? if so no use to me. Extension lead ? Re: Hand tools: alternative replacement/s for an angle grinder. - His Dudeness - 05-05-15 Just file it off with a hand file. I'd guess a good quality file would cost a tenner. It'd take about 10 seconds to file the head off a chain pin
Re: Hand tools: alternative replacement/s for an angle grinder. - crickleymal - 05-05-15 Inverter hooked up to the car battery? Re: Hand tools: alternative replacement/s for an angle grinder. - Tmation - 05-05-15 Just get a chain splitter and riveter You can get them cheaper, but a good one lasts a lifetime. http://www.ebay.co.uk/itm/Heavy-Duty-X-ring-Motorcycle-Chain-Breaker-Spliter-Motorbike-Riveting-Tool-Link-/251884152742?pt=LH_DefaultDomain_3&hash=item3aa57727a6 Re: Hand tools: alternative replacement/s for an angle grinder. - stevierst - 05-05-15 Bought a cheapo aldi special grinder couple of years ago, abused the living daylights out of it making allsorts of metallic contraptions. It's still going strong, only cost me £15-£20. Re: Hand tools: alternative replacement/s for an angle grinder. - b1k3rdude - 05-05-15 (05-05-15, 10:04 AM)fazersharp link Wrote: Extension lead ?Not possible, hence needed a cordless. (05-05-15, 10:12 AM)His Dudeness link Wrote: Just file it off with a hand file. I'd guess a good quality file would cost a tenner. It'd take about 10 seconds to file the head off a chain pinThe pins on your average chain are hardened, the file would just slide over them. Re: Hand tools: alternative replacement/s for an angle grinder. - fazersharp - 05-05-15 Quote:The pins on your average chain are hardened, the file would just slide over themno because the file is hardenerery, thats how they work so they remove stuff and not themselfs Re: Hand tools: alternative replacement/s for an angle grinder. - His Dudeness - 08-05-15 The pins are riveted together right? So they are ductile not hardened. Hardening them would make them more brittle so they'd crack from stress rather than plasically deform to create the rivet head. A decent file will go through it no problem. But you don't even have to file the head off just use a chain breaker or you could even hack saw it if you wanted Re: Hand tools: alternative replacement/s for an angle grinder. - Nebuchernezzer - 08-05-15 You can knock the pins out with a hammer and a centrepunch if you can hold the chain solidly enough. The squashed over pin heads deform and slide through the chain rollers after a few good whacks. |
