Chain cleaner: is it a big con? - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: General (https://foc-u.co.uk/mybb/forumdisplay.php?fid=65) +--- Forum: General (https://foc-u.co.uk/mybb/forumdisplay.php?fid=69) +--- Thread: Chain cleaner: is it a big con? (/showthread.php?tid=72412) Pages:
Chain cleaner: is it a big con? - b1k3rdude - 04-05-15 Like bottled water, I feel that paying upwards of £7 for only 400ml that dosent look like it will last beyond 3-4 uses is a complete rip-off. I am convinced that I/we can get the a bigger quantity of same chemicals/solvent that will do the same job at a fraction of the price and not damage the o-rings on our drive chains. Does anyone know what the ingredients of the most chain cleaners are, or failing that a diy alternative that will do the same job. Re: Chain cleaner: is it a big con? - Grayo - 04-05-15 I've always used paraffin. Does a great job and easy to dry off and re lube after. Re: Chain cleaner: is it a big con? - NorthWestern - 04-05-15 +1 for paraffin. £6 for 4 litres (even from high Street places) stiff brush and a rag. Re: Chain cleaner: is it a big con? - mickvp - 04-05-15 I must admit I have tried a few of these "speciality" products before. I find paraffin usually works just as good if not better :o Re: Chain cleaner: is it a big con? - b1k3rdude - 04-05-15 I knew about paraffin, but heard it can effect the O-Rings. How many miles have you guys gotten from a chain, before and after using paraffin..? Re: Chain cleaner: is it a big con? - NorthWestern - 04-05-15 Tens of Thousands. My current one I put on just before Xmas and it's done about 11k now. I do have scotoiler on too. It has never caused a seal issue, I used it on my crf450 too, perfect results. Re: Chain cleaner: is it a big con? - noggythenog - 04-05-15 What's wrong with wd40 then guys...thats what i used...have i focced up? Mt thought was to use it to clean and then go over drying it off with a rag before app,ying fresh lube. Re: Chain cleaner: is it a big con? - acid drop - 04-05-15 (04-05-15, 05:32 PM)Grayo link Wrote: I've always used paraffin. Does a great job and easy to dry off and re lube after. Paraffin for me as well Re: Chain cleaner: is it a big con? - johnakay - 04-05-15 Paraffin doesn't do any harm to 'O' rings or 'X' rings. [/size]if any thing it may swell them a little bit which isn't a bad thing. [/size]paraffin is slightly oily so it won't harm your chain. [/size]brush plenty on to get the muck loose and wipe off with a rag but do n't do it with engine running in gear. [/size]turn the wheel by hand. [/size]this is what happens clean[/size]ing with engine running. ![]() Re: Chain cleaner: is it a big con? - noggythenog - 04-05-15 I also used this blinds cleaner...for a joke may i add....my missus was gonna chuck it so im like nah nah thats useful ill keep that...she said i wouldnt use it....so out i went just to prove her wrong...she doesnt know it was nigh on useless :b .....good old toothbrush and elbow grease did the trick in the end. Re: Chain cleaner: is it a big con? - noggythenog - 04-05-15 Jesusfoccinchrist johnakay :eek :eek :eek Ive done my thumb nail before on the sprocket on my 600 but thats hardcore. Re: Chain cleaner: is it a big con? - slimwilly - 04-05-15 I use petrol,,not had any problems over the years I have done so,,get a drip tray under the chain,,wash it with a paint brush ,,and any where else where gunk has flown,,then dry it well,,,well most of it evaporates,,give it a damn good wipe with tissue,,cloths,,, Then I re-lube it,,and wipe the side links of the chain dry,,don't want too much lube lying around. I did this two days ago as I had been using white chain wax,,,wish I had not,,it over sprays grease everywhere,,and leaves too mush on the chain,,so I cleaned it and found the last bit of silcolene chian no fling,,my favourite,,checked it after this afternoons 100 miler and nice and clean and no fling.. ![]() Re: Chain cleaner: is it a big con? - b1k3rdude - 04-05-15 (04-05-15, 06:33 PM)noggythenog link Wrote: What's wrong with wd40 then guys...thats what i used...have i focced up?Lot of places/people have said not to use it and the only thing I can think of is because its water based. @John well, what can I say that you haven't said to yourself or had said to you. Hope you didn't permanently loose any function in the finger tips.. And regarding cleaning the chain its not rocket science, I just dont want to be spending uncessary cash etc. How do you paraffin boy's apply it, pump sprayer..? Re: Chain cleaner: is it a big con? - mtread - 04-05-15 Occasional Paraffin + Scottoiler = at least 30K miles. More likely 40 - 50 ![]() Re: Chain cleaner: is it a big con? - bigralphie - 05-05-15 GT85 (get it cheap at work) and one of these http://www.ebay.co.uk/itm/Chain-Brush-Motorcycle-Cycling-Bike-Crankset-Brush-Cleaner-Cleaning-Tool-Red-/400669118134?pt=LH_DefaultDomain_3&hash=item5d49bd8eb6 Re: Chain cleaner: is it a big con? - stevierst - 05-05-15 Bought a big tin (5 litres) of de-greaser for about £10, and use it regular. It's lasted a few years with no probs. It's paraffin based by the smell of it. And use a Scottoiler. It's an absolute no brainer to double the life of your chain! Re: Chain cleaner: is it a big con? - His Dudeness - 05-05-15 Give a bit of warning before you put up pictures of mangled body parts Re: Chain cleaner: is it a big con? - Grayo - 05-05-15 (04-05-15, 11:28 PM)b1k3rdude link Wrote: How do you paraffin boy's apply it, pump sprayer..? Put it on with a paint brush and wipe it off with some old rags. Re: Chain cleaner: is it a big con? - His Dudeness - 05-05-15 used engine oil and a tooth brush works fine. wipe it off with a rag Re: Chain cleaner: is it a big con? - stevierst - 05-05-15 I used to put old engine oil in my chain oiler when I was covering 30k+ per year. It was one way of recycling it, but hell did it make a mess of the back end of the bike. |
