seized lower leg adjusters how to fix - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: Fazer 1000/FZ1 corner (https://foc-u.co.uk/mybb/forumdisplay.php?fid=75) +--- Thread: seized lower leg adjusters how to fix (/showthread.php?tid=72376) |
seized lower leg adjusters how to fix - devilsyam - 30-04-15 this is my way works for me there may be other ways if the adjuster is solid as this welsh won was after a winters riding DONT force it do as this picture [img height=456 width=251]https://scontent-lhr.xx.fbcdn.net/hphotos-xfp1/v/t1.0-9/10407968_10152995476353800_8859166205615816412_n.jpg?oh=638227d90e481372620fc09100ef4466&oe=559A42DD[/img] any bit hose will do fill with penatrating fluid and leave 24 48 hours then gently see if any movment make sure screwdriver is correct for slot or you will foc it work back and forward gently if still rock solid leave bit longer and repeat last resort the ring around the adjuster is ally gently heat with paint stripper you will no when hot enough as fluid will fizz up whilst hot spray pen fliud and leave to cool luke Re: seized lower leg adjusters how to fix - nickodemon - 30-04-15 I had a gen 1 that had seized adjusters and tried soaking in silkopen, also using heat spray and freezing spray. i soaked them for days and even used my blow torch and couldn't get them to budge. I gave up and gave them to a bike shop. They gave them back saying they were freed off, but what they actually did was free off the aluminium housing so everything rotated
Re: seized lower leg adjusters how to fix - unfazed - 30-04-15 I used a similar set up to Luke, but used diesel, worked a treat, but took about a week of heating, cooling, twisting. Bike had spent 2 years out in all weather and in everyday use in all weather around London/M25. Make sure the screwdriver is a good fit and as Luke said do not force it. Re: seized lower leg adjusters how to fix - devilsyam - 01-05-15 prevention is way easier for thoose all round riders i suggest cover them in vasiline keep the crap out Re: seized lower leg adjusters how to fix - b1k3rdude - 02-05-15 Had the same issue with one of previous thou's a few years ago, I just squirted Fuchs graphite penetrating fluid (sourced from local ktm dealer) into/on them before and after each ride for a 5 days then on Saturday they moved retentively easily with a wide flat blade screwdriver. (01-05-15, 05:10 PM)devilsyam link Wrote: prevention is way easier for thoose all round riders i suggest cover them in vasiline keep the crap out+1, don't forget to reapply every wash etc. |
