rear end too light or just me? - Printable Version
+--- Thread: rear end too light or just me? (/showthread.php?tid=72209)
Pages: 1 2
rear end too light or just me? - Paulfzs - 16-04-15
im about 11 stone, took the bike out for some fast paced roundabouts and straights near redline in 3rd for most of it with some mates, problem i found which almost put me into the lane divide was when i downshift or rear break a bit hard my back locks up and skips along the floor.
any ideas?
my rear shock appears to be on its hardest setting but its not solid.
Re: rear end too light or just me? - darrsi - 16-04-15
What's the story with the rear shock?
Original, old, upgraded?
Re: rear end too light or just me? - Paulfzs - 16-04-15
as far as im aware original shock.
it doesnt feel super bouncy it doesnt feel massively hard, would making it softer help combat the back skipping as it would compress more
Re: rear end too light or just me? - fazersharp - 16-04-15
So you are in 3rd - red line and downshifting to 2nd and asking why the back is skipping and locking up.
Yes I know Im paraphrasing a little but-------------- well !
(16-04-15, 06:20 PM)fazersharp link Wrote: So you are in 3rd - red line and downshifting to 2nd and asking why the back is skipping and locking up.
not changing down from 3rd to 2nd at redline but its still pretty high rpm
Re: rear end too light or just me? - Yamazer-92 - 16-04-15
Put some bricks in your top box, that's what I did. Not a large Hawaiian dominoes though, that never ends well after a Raz.
You have of course heard of "blipping" the throttle when clutch is in when down shifting to counter engine braking. Just checking
Mileage?
Re: rear end too light or just me? - noggythenog - 16-04-15
I dont use my back brake, but surely any bike will lock the rear if there isnt enough weight on it ie under braking....but the 600 back brakes are rubbish anyway....far as ive figured out the back brake is for slow speed maneouvering or for initially loading up the front end aint it?
Re: rear end too light or just me? - kebab19 - 16-04-15
It sounds like the damping on your shock might be on the way out, what sorta mileage has it done?
Failing that, the max preload setting might not be a good match for your weight
Re: rear end too light or just me? - Punkstig - 16-04-15
/\ someone's phishing for business, spare R6 shock by chance?
I kid of course!
On a serious note, I weigh about 12.5 stone in my riding gear and was on preload 5 or 6 of 9 on the OEM shock which was correct sag wise, so having it on 9 sounds way too much if you're 11 stone. If your rear wheel is "skipping" I would probably suggest you're down-shifting without blipping the throttle to match the RPM like fazersharp said which will mean the engine braking / drive chain will make the wheel lock. The standard rear brake would have to be applied pretty hard to lock the rear wheel noticably at near redline in 3rd gear speeds unless you had the fronts on very hard as well. Have you checked your swing arm bearings and shock bearings?
(16-04-15, 08:56 PM)Punkstig link Wrote: /\ someone's phishing for business, spare R6 shock by chance?
I kid of course!
Hahaaaa love it  Smile
No need, our youngest FZS600's are now 12 years old and with age the rear shocks mature like a fine wine... not
Re: rear end too light or just me? - mtread - 16-04-15
Most 600 original rear shocks are knackered after 20K miles, but then they tend to go soft rather than hard (oo-er) and bounce around or sag. Perhaps it's seizing. What's it like just sitting on it and bouncing up and down ?
if its original itll be 44,000 miles.
the locking up isnt a problem i can live with the back end sliding its the skipping i cant deal with because i have no control over the bike at all, it locks up and the rear wheel bounces.
ill get on it tomorrow and slacken off the shock, ive spent too much on this to change the shock at the moment.
So do you actually use the "blip" technique as you did not say, if not then give it a go
I'd guess you're just in the wrong gear at too high revs that's causing the locking up.
And your shock should be well and truly knackered by now i'd imagine!
Re: rear end too light or just me? - midden - 17-04-15
slacken the preload by a few steps, you'll notice the difference
Re: rear end too light or just me? - slimwilly - 17-04-15
Get a far girlfriend :lol :lol :lol :lol :lol
Re: rear end too light or just me? - darrsi - 17-04-15
(17-04-15, 07:44 AM)slimwilly link Wrote: Get a far girlfriend :lol :lol :lol :lol :lol
Typo's can really spoil a joke.  :rollin
