sidestand cut out switch not working - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: Fazer 1000/FZ1 corner (https://foc-u.co.uk/mybb/forumdisplay.php?fid=75) +--- Thread: sidestand cut out switch not working (/showthread.php?tid=72093) |
sidestand cut out switch not working - samsung - 07-04-15 Before i remove the the said item,any advice would be much appreciated.The small piston is operating ok on the switch so i'm guessing it is the contacts inside it.Can i take it out of the loop easily?I have never had a bike that had one fitted.Any advice please will be welcome. Re: sidestand cut out switch not working - unfazed - 07-04-15 Easy enough to bypass, but I would certainly would not recommend it for the same safety reasons it exists. Take it off and try spraying contact cleaner or WD40 into the area by the plunger, I have done this and it has brought a few back to life after operating it numerous times by hand. Many give trouble because the corrode from lack of use Same as the Carburettor model R6 Later 04/05 ones were upgraded Re: sidestand cut out switch not working - samsung - 08-04-15 Thanks for the advice.I've had the bike off the road for 18months,will pick up some contact cleaner today and give it a go.
