Not turning over, help!! - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: Not turning over, help!! (/showthread.php?tid=72049) |
Not turning over, help!! - Bondyboy96 - 03-04-15 Help! So I removed the starter relay a few days ago, to clean the contacts on it and the ring terminal thay goes to the fuse snapped so I bodged it with a wire and spade connector, refitted it, press the starter and nothing -_- no surprise there tho. Got a new starter relay, fitted it and stull nothing. Any ideas? Checked all switches etc and cant see any issues ![]() Cheers guys Re: Not turning over, help!! - ChristoT - 03-04-15 Check fuse, check battery? Re: Not turning over, help!! - Bondyboy96 - 03-04-15 Yeah done fuses, battery etc, battery is only a month old aswell Re: Not turning over, help!! - sinto607276 - 03-04-15 Are you sure your 'botched' job you've done is sound? Re: Not turning over, help!! - unfazed - 04-04-15 (03-04-15, 11:22 PM)sinto607276 link Wrote: Are you sure your 'botched' job you've done is sound? :lol :lol :lol Re: Not turning over, help!! - ChristoT - 04-04-15 (03-04-15, 11:06 PM)Bondyboy96 link Wrote: Yeah done fuses, battery etc, battery is only a month old aswell Doesn't mean it's charged. Also, Sinto has a valid point - checked the connections with a multimeter? Re: Not turning over, help!! - Bondyboy96 - 04-04-15 Yeah battery is fully charged haha and got a new starter relay on anyway and still doing nothing, but connections were sound and had good resistance when checked anyway
Re: Not turning over, help!! - Fazerider - 04-04-15 Killswitch?
Re: Not turning over, help!! - sinto607276 - 04-04-15 Has it been knocked into gear? That would give you the same affect. Re: Not turning over, help!! - Bondyboy96 - 04-04-15 Killswitch is off and its in neutral :/ Re: Not turning over, help!! - andybesy - 04-04-15 Checked the side stand sensor is not stuck? Andy Re: Not turning over, help!! - sinto607276 - 04-04-15 Is there not a main fuse near the other fuses? Could that be blown? Are you getting all the lights on the dash and other lights working? Another thought, years ago with my honda cbr my starter was playing up and got nothing when trying just like you, ended up the bushes in the starter were dodgy, it needed a wee tap on the starter unit to knock the bushes round enough to make a contact, maybe worth a try? |
