Downpipe and exhaust gaskets - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: Downpipe and exhaust gaskets (/showthread.php?tid=72018) |
Downpipe and exhaust gaskets - davidkent - 31-03-15 As above really. I can't find anything definitive, I'm looking at replacing the gaskets throughout but don't know what I should have or need. Assuming there's 4 at the front, are there any further back? I've an aftermarket link pipe and what I believe to be a delkovic can too, but that all blows so I wanna do it all really. Amyone got any links? Not fussed if it's ebay or elsewhere ![]() Thanks chaps Re: Downpipe and exhaust gaskets - anutz - 31-03-15 will be keeping an eye on this... I changed my end can for a Scorpion, its blowing/dripping a bit, but they advised just to use some heat tolerant silicon ( have some 600+ stuff ) on the join and tighten the clips well....so plan to do that..there is not room for a gasket there anyway in my case, it would be wafer thin and not really compress, its tight but not air tight... But i am in the process of getting my down pipes off, waiting for plus-gas, bolts seized.... Not sure if i will need to renew the gaskets either... Re: Downpipe and exhaust gaskets - bandit - 31-03-15 Anutz & davidkent you will both need 4 gaskets for the front down pipes,aftermarket link & endcans normally don't have gaskets hence the heat resitant silicone used by Anutz. Anutz have a good look at those pipes as it maybe better if your can to get some new stainless ones from Motad,give them a ring for a better price as I & others have on here,if you replace them you will need to balance the carbs. Re: Downpipe and exhaust gaskets - darrsi - 31-03-15 Get gaskets from here: http://www.wemoto.com/bikes/yamaha/ Re: Downpipe and exhaust gaskets - anutz - 01-04-15 shall take a look at the Motad stuff, and the gaskets... Cheers Re: Downpipe and exhaust gaskets - davidkent - 01-04-15 So copper or alu fibre? Lol cheers Re: Downpipe and exhaust gaskets - bandit - 01-04-15 I went for the Alu/fibre as fitted originally. Re: Downpipe and exhaust gaskets - davidkent - 01-04-15 Ideal, cheers |
